2000 Civic Si Front Knuckle Bad??
Old Jun 22, 2006 | 10:24 AM
purduinasi's Avatar
Default 2000 Civic Si Front Knuckle
Nevermind.. mods can delete this
Modified by purduinasi at 2:23 PM 6/22/2006
Old Jun 22, 2006 | 11:35 AM
ffHeart's Avatar
Default Re: 2000 Civic Si Front Knuckle Bad?? (purduinasi)
What are they claiming is the damage to the knuckle?
The wheel bearing is a sealed unit. The wheel bearing + hub assembly is pressed into the knuckle. Under normal conditions, you will have some wear on the hub race/knuckle from pressing new bearings in and out. In extreme cases, I've seen damage to the hub from improper installation or removal of the wheel bearing.
I would ask to see the damage before you make a decision.
Old Jun 22, 2006 | 12:19 PM
purduinasi's Avatar
Default Re: 2000 Civic Si Front Knuckle Bad?? (whitewonder)
turns out they're idiots and it was the hub that was bad, not the knuckle... thanks though!
Old Jun 22, 2006 | 12:53 PM
ffHeart's Avatar
No problem.
civic-steve-94
Aug 15, 2015 03:03 PM
Vladvyg
Honda Civic (2006 - 2015)
Jul 4, 2015 05:23 AM
z6hatchboy
Feb 6, 2009 06:31 PM
mikekc99
Sep 16, 2008 05:44 PM
ghettoracer
15
Feb 2, 2005 08:42 PM
