1st gear question
Old Aug 3, 2005 | 11:15 PM
emissionsux's Avatar
Default 1st gear question
I was wondering the easiest way to tell the difference between a B16 1st and a GSR 1st. I'm trying to find a GSR 1st gear to mate with my 4.4 FD. Thanks
Old Aug 4, 2005 | 10:48 AM
Default Re: 1st gear question (emissionsux)
Anyone?
Old Aug 4, 2005 | 11:19 AM
slofu's Avatar
if they are both from hydro trannies, aren't they both the same ratio with dual-cone synchros? i know that for the jdm 4.7 fd the 1st counter gear ID is different since it goes over a collar (the usdm one doesn't). dunno if any jdm 4.4s are different from usdms this way. if it doesn't use the dual-cone synchro, the ls 1st should be the same. (all of the hydro 1st gear B ratios are 3.23:1.)
http://www.hondaautomotivepart...EC%29
http://www.acuraautomotivepart...y.jsp
ok, apparently the hydro LS doesn't use dual-cone synchros between 1-2, but the 94 b16 del sol tranny has them, as does the 99-00 si tranny, and even the 92-93 b17a gsr, like the b18c trannies- gsr and itr.
the sites linked above have been known to have flawed info before, but it seems like you'll have no problem as long as you use 1st gears from 2 hydro b vtec trannies with the 4.4fd.
Modified by slofu at 3:47 PM 8/4/2005
Old Aug 5, 2005 | 08:45 AM
Default Re: 1st gear question (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">if they are both from hydro trannies, aren't they both the same ratio with dual-cone synchros? i know that for the jdm 4.7 fd the 1st counter gear ID is different since it goes over a collar (the usdm one doesn't). dunno if any jdm 4.4s are different from usdms this way. if it doesn't use the dual-cone synchro, the ls 1st should be the same. (all of the hydro 1st gear B ratios are 3.23:1.)
Modified by slofu at 3:47 PM 8/4/2005</TD></TR></TABLE>
That's what I thought.....if they are both from a hydro tranny and share the exact gear ratio....in theory, they should be interchangeable. But someone told me otherwise, and I am just trying to varify the information. Because I have a 4.4 out of a GSR, and all I can find are 1st gears from an SI.
Old Aug 5, 2005 | 09:58 AM
slofu's Avatar
they're the same. it's the fd ring gears which are different. while they have the same # teeth on countershaft and ring gears, the IDs of the rings differ, since the hydro ls and b16 diffs have a smaller housing than the hydro gsr/itr/ctr diffs.
Runnerdown
Apr 16, 2013 06:50 PM
dc2r_integra
Aug 7, 2006 03:28 PM
kmar111
Jun 6, 2004 02:48 AM
typeass
Apr 4, 2004 11:25 PM
7rrivera7
Dec 3, 2002 06:08 AM
