1998-01 Integra owners check within
Old Mar 2, 2003 | 09:05 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default 1998-01 Integra owners check within
In search of a 1998-01 Integra owner with a Helms manual and/or something lower or equal to a Helms, that would provide assistance. Any manual or answer from anyone that knows the 16 pin layout for the blue harness of the gauge cluster. There are two blue plugs consisting of a 13 and 16 pin found behind gauge cluster of the Integra dash, along with them is also a yellow plug. In search of the individual functions for the 16 pin from left to right. Example: red/green fuel, yellow/black ground. If you have the 13 pin as well and would like to give it I would greatly appreciate any answers, sites, or other members you could direct me to. I appreciate your time and efforts, thanks.
Old Mar 2, 2003 | 01:30 PM
INVALID's Avatar
Default Re: 1998-01 Integra owners check within (SHAUNTS99)
bump
Old Mar 2, 2003 | 05:23 PM
SSBP DC2's Avatar
the 16 pin connector is called the B connector
the 13 pin connector is called the D connector
look at it from left to right with B1 (or D1) being the #1 pin on the left handside, with the plug right side up (how it's suppose to be when it's plugged into the gauge cluster and you're looking at it from the driver's POV).
B1 = seat belt reminder
B2 = door open indicator
B3 = fuel gauge unit
B4 = low fuel light
B5 =
B6 = speedometer drive circuit
B7 = hatch (trunk) open indicator
B8 = abs indicator light
B9 = gauge lights (from fuse)
B10 = gauge lights (from dimmer)
B11 = charging system light (from battery)
B12 =
B13 = left turn indicator
B14 = right turn indicator
B15 = high beam indicator
B16 = parking brake light
D1 =
D2 = maintenance reminder
D3 =
D4 = cruise control (from fuse box)
D5 = cruise control (from cruise control unit)
D6 = ground for high beam indicator
D7 = coolant temp gauge
D8 =
D9 = charging system light (from alt)
D10 =
D11 = low oil indicator
D12 = malfunction indicator
D13 = tachometer driver circuit
D2 and D9 were designed to be isolated on purpose, take a guess why
this is for reference only. It may be right and it may be wrong....but it's taken straight out of a honda service manual for 95 integra GSR. i take no responsibility for your action should you decide to be creative. Have fun
Old Mar 2, 2003 | 05:27 PM
SSBP DC2's Avatar
Default Re: 1998-01 Integra owners check within (SSPB DC2)
reminder, this info is off of a 1995 GSR.
i know you asked for 98-01, a couple of lights are different i believe.
Old Mar 3, 2003 | 12:13 AM
INVALID's Avatar
Thanks, it helps with some of the information I have been attempting to confirm here, even if it is the '95 it gives a layout of what I was looking at previously with a few more notes.
Dig the disclaimer towards the end
Old Mar 3, 2003 | 10:09 AM
SSBP DC2's Avatar
okay np
4cefedcrx
Oct 17, 2006 07:13 AM
Zatzy
Jun 29, 2005 06:56 AM
Got Milk
Jan 22, 2005 10:36 AM
INVALID
Mar 3, 2003 06:45 AM
eric.
Oct 17, 2002 04:30 PM
