1981 honda express moped!!
Old Jul 7, 2003 | 01:05 PM
92civeg's Avatar
Default 1981 honda express moped!!
anyone have a wiring diagram for a 1981 honda express moped i have one that is not running and i would like any info on them if anyone has it
thanks
Old Jul 7, 2003 | 06:30 PM
92civeg's Avatar
Default Re: 1981 honda express moped!! (92civeg)
Old Jul 7, 2003 | 07:49 PM
MADEINIRAQ's Avatar
i have one.
pretty sure.. let me search around
Old Jul 7, 2003 | 08:00 PM
MADEINIRAQ's Avatar
Default Re: 1981 honda express moped!! (madeiniraq)
found it...
i'm pretty sure this is for an 81.
i've had quite a few honda mopeds and from my experience the wiring is exaclty the same.
Old Jul 7, 2003 | 08:40 PM
92civeg's Avatar
hey thanks a lot ..i can get this moped for 50 bucks but right now it isnt running its in grat condition but i think it needs a new condenser or someting mabye just a new battery when you kick the kick start it sound like its gonna do something but doesnt ...it might just be the battery because none of the electrical equiment is working now lights blinkers etc...do they still make parts for this ..any idea of what it could be??
Old Jul 7, 2003 | 08:53 PM
MADEINIRAQ's Avatar
you can get any part from honda.
clogged exhaust is pretty common torch the muffler and let everything drain out
Spark plugs go bad
bad gas.
i currently have an 82 express and i put really old gas in it and it doesn't wanna start but it does after a bunch of kicks.
there is a moped forum somewhere around.. haven't been on it since i was 15, i'm now 18
Old Jul 7, 2003 | 09:00 PM
92civeg's Avatar
does the motor have to be running for the electronics to work??? ...what is torching the muffler..... does it take striaght gas or is it a gas oil mix..what does the **** under the seat have to be turned to to start it fuel on off normal....
thanks for all the help
Old Jul 7, 2003 | 09:07 PM
MADEINIRAQ's Avatar
for the electronics to work.. i think it has to be running.
the muffler gets clogged with oil and you have to heat it up with a torch and drain out all the crap inside so it flows again.. common fix for a barely running moped or a really slow one.
for the gas.. there should be a separate oil tank.. if not then you have to premix. not sure what mix though. my moped has separate oil tank
for the gas ****. just put it on or reserve doesn't matter what position as long as it is on.
Old Jul 7, 2003 | 09:13 PM
92civeg's Avatar
yeah there is a seperate oil tank i filled it up with gas today but i did not add any oil think that cluld be the prob? is there any way u can make the diagram a little larger i cant see the wire colors
thanks
Old Jul 8, 2003 | 09:52 PM
92civeg's Avatar
ok well i orderd a ignition coil today hopefully that will fix it also when i was changing the spark plug today the plug wire broke (23 years old) do i have to order a new one from honda or can i just get one for a car or lawn mower??
Old Jul 9, 2003 | 09:52 AM
92civeg's Avatar
ok well it turns out that honda discontinued making those ignition coils anyone got one to sell?????
Old Jul 9, 2003 | 11:36 AM
92civeg's Avatar
its a
Old Jul 9, 2003 | 01:44 PM
MADEINIRAQ's Avatar
is it 6 volt or 12 volt system.. I would try ebay for a coil.
Old Jul 9, 2003 | 02:12 PM
92civeg's Avatar
im not sure what volt system it is what exactly does the ignititon coil do?? ..what about a plug wire can i use one froma car or do i have to get one for the moped
Old Jul 9, 2003 | 11:18 PM
92civeg's Avatar
help i need a daily driver!!!!!!!!jk
ryanfried
Jun 20, 2018 07:17 PM
Hondaontheroad
Feb 20, 2018 08:12 AM
lakshmiviln
Honda CR-V & Element
Jul 25, 2017 08:17 PM
C_H_A_D
Aug 5, 2004 04:41 PM
SuzukaBlueAP2
Acura TL, RL & ZDX
Sep 10, 2003 05:29 AM
