16:1 a/f on the freeway safe????
Old Feb 1, 2006 | 09:47 PM
  #26
b16hybridsol's Avatar
Default Re: (AutoEng2002Si)
condensation on the outside of parts ha
Old Feb 1, 2006 | 10:08 PM
  #27
Scott_Tucker's Avatar
Default Re: (b16hybridsol)
OK, I hear ya
Old Feb 2, 2006 | 08:06 PM
  #28
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoEng2002Si &raquo;</TD></TR><TR><TD CLASS="quote">
Methanol is a completely different fuel than gasoline. Its stoichiometrically correct mixture is way different than that of gasoline. Methanol actually contains less energy per lb. than gasoline so you are correct in saying that it is not the methanol in itself that is adding the power. It is the heat of vaporization of methanol that allows it to make such high amounts of power. It has the ability to draw heat out of the intake charge (as you mentioned), therefore making it less prone to detonation so you can run higher compression ratios, and therefore expansion ratios making the engine more efficient.</TD></TR></TABLE>
i didn't want to say all that. i kept it veeeery simple. thanks for doing all the work for me hahaha.
Type-ARR
Oct 9, 2007 09:07 PM
mart1976
Nov 23, 2006 10:43 AM
lude98SH
Mar 16, 2006 12:56 PM
JCCOOL43
Jun 13, 2003 03:15 AM
niedejb
Feb 13, 2003 01:47 PM
