12.5 compression piston cc's
Old Mar 14, 2007 | 06:35 PM
Lubo_25's Avatar
Default 12.5 compression piston cc's
just need to know an approximate number for the amount of cc's protruding...refering to material sticking out pretty much
Modified by Lubo_25 at 9:06 PM 3/14/2007
Old Mar 15, 2007 | 03:07 AM
NJIN BUILDR's Avatar
Default Re: 12.5 compression piston cc's (Lubo_25)
For a b18 it's around 6.7cc.
Old Mar 15, 2007 | 09:03 AM
NJcoupe's Avatar
Default Re: 12.5 compression piston cc's (NJIN BUILDR)
It all depends on the bore.
Old Mar 15, 2007 | 09:36 AM
Lubo_25's Avatar
Default Re: 12.5 compression piston cc's (idriveacoupe.)
its an 89 mm bore btw so im gonna guess around 10 or close to??
Old Mar 15, 2007 | 05:31 PM
K24 ?
What are you running a 89mm in ?
Old Mar 15, 2007 | 05:41 PM
Lubo_25's Avatar
its for an h22 setup im doing...
Old Mar 15, 2007 | 05:46 PM
http://www.jepistons.com/cat/j...shtml
Looks like 89mm would be a custom.
Old Mar 15, 2007 | 05:50 PM
Lubo_25's Avatar
they're custom...x-forgings from cp pistons...
Old Mar 15, 2007 | 06:10 PM
Didn't you say JE originally? From the look of JE'd 88mm dome you probably around 10.5 cc's or so.Give CP a call,they can tell you exactly.
Old Mar 16, 2007 | 07:52 AM
Lubo_25's Avatar
either that or email them i think...thanx man for the input!
moe-teg
May 30, 2008 01:29 AM
kazino42
May 22, 2005 09:44 AM
93H22ACX
May 18, 2004 04:55 PM
PM-Performance
Apr 28, 2003 09:33 AM
DSGB.
Dec 25, 2001 09:20 AM
