1.5 vetec limited????
iv just bought a 1998 5 door 1.5 vetec. it pulls good and is fine driving but wont go above 115mph, its only doing 5k when i get to 115mph and it feels as if the car is limited to this speed.
are these cars limited in speed or is there a problem with my engine
engine code is d15z8
Hi, welcome to H-T. From what I have hear of those engines the transmission is your issue. I couldn't find too much info on it but it also isnt that high of a powered engine, I believe max at 114hp. Here is a quick link I pulled up on the search up in the top corner, first place to start is there. https://honda-tech.com/zerothread?id=336907. And before anyone starts to poke fun, its spelled VTEC, good luck with your car
it's called a speed limiter. it's like hitting a revlimiter but it's speed based.
It's built into the ECU, only good way to get rid of it is to convert to OBD1, tune and disable the speed limiter.
it's spelled VTEC (as stated above)
D15Z8 = no VTEC (as far as I know, I could be wrong)
and why are you trying to go above 115mph? no track will have long enough straights to get there with the power you have, and hopefully you're not exceeding the speed limit that bad. (and admitting it)
The D15Z8 was one of the 3-stage VTEC engines, nothing special. And I totally agree there is no reason to be going that fast
No need for that trust me, I've been there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">The D15Z8 was one of the 3-stage VTEC engines....</TD></TR></TABLE>
3-stage vtec? your a dumbass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">
Umm yes there is such a thing, I wouldnt be so quick to call someone a dumbass when you obviously know very little. I hate dumb H-Ters
</TD></TR></TABLE>Umm yes there is such a thing, I wouldnt be so quick to call someone a dumbass when you obviously know very little. I hate dumb H-Ters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">The D15Z8 was one of the 3-stage VTEC engines, nothing special. And I totally agree there is no reason to be going that fast
No need for that trust me, I've been there.</TD></TR></TABLE>
His info says he is from glasgow scotland. I think speed isnt an issue over there is it? Just wondering.
No need for that trust me, I've been there.</TD></TR></TABLE>His info says he is from glasgow scotland. I think speed isnt an issue over there is it? Just wondering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DecentCivicZ6 »</TD></TR><TR><TD CLASS="quote">yeah isnt that the VTEC-E engine? economy.</TD></TR></TABLE>
im not sure, it was my understanding that the vtec e engine was on the us spev HX model civic was a 1.6 and had roller cams.
i know us spec civic dx 1.5 non-vtec from 92-95 have the same rev limit in 5th gear.
Your a retard now pay attention..vtec cams have TWO profiles only. when the pins in the rockers lock, you are on the vtec cam. there is no such thing as "3 stage". that is the funniest thing i've ever heard. You should be SMACKED for that. Anyway, your a dumb ***. The only thing CLOSE to that is GSR motors have secondaries, in the intake manifold, that open up at a certain RPM. then, the vtec crosses over a bit later. Maybe that is what you mean. still, the secondaries have nothing to do with vtec. YOU A DOUCHe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">Your a retard now pay attention..vtec cams have TWO profiles only. when the pins in the rockers lock, you are on the vtec cam. there is no such thing as "3 stage". that is the funniest thing i've ever heard. You should be SMACKED for that. Anyway, your a dumb ***. The only thing CLOSE to that is GSR motors have secondaries, in the intake manifold, that open up at a certain RPM. then, the vtec crosses over a bit later. Maybe that is what you mean. still, the secondaries have nothing to do with vtec. YOU A DOUCHe
dude, shut up...there is a such thing as a 3-stage vtec system, it incorporates vtec-e and the normal vtec function into one.
notice the dual solenoids and different rocker design? you try so hard to be wrong
insta-Ban
https://honda-tech.com/zerothread?id=2011797
BTW heres the link to the thread
</TD></TR></TABLE>dude, shut up...there is a such thing as a 3-stage vtec system, it incorporates vtec-e and the normal vtec function into one.
insta-Ban
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">vtec-e
3 stage vtec? blahh
i have an hx i know what the expletive vtec-e is.
Its vtec-e.
not 3 stage vtec, that was my point
theres a difference between a engine with vtec-e making About 90hp and one with vtec-e until 3000k rpms, and from then on it has the same power output as a jdm d15b with a normal vtec cross-over. all of the advances towards the i-vtec technology.
3 stage vtec? blahh
Its vtec-e.
</TD></TR></TABLE>theres a difference between a engine with vtec-e making About 90hp and one with vtec-e until 3000k rpms, and from then on it has the same power output as a jdm d15b with a normal vtec cross-over. all of the advances towards the i-vtec technology.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
theres a difference between a engine with vtec-e making About 90hp and one with vtec-e until 3000k rpms, and from then on it has the same power output as a jdm d15b with a normal vtec cross-over. all of the advances towards the i-vtec technology.</TD></TR></TABLE>
now theres somethin u cant argue about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DecentCivicZ6 »</TD></TR><TR><TD CLASS="quote">roller cams? u saying they had roller rocker arms? lol</TD></TR></TABLE>
yeah, i grew up around v8 guys, they call'em roller cams, but yeah.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
yeah, i grew up around v8 guys, they call'em roller cams, but yeah.</TD></TR></TABLE>
haha word, well hondas dont have roller rocker arms from factory
haha word, well hondas dont have roller rocker arms from factory</TD></TR></TABLE>
dont the K's?
dont the K's?
the k-series, f20/f22c s2k engines, d15z1(or JDM EQUIVILENT), f22/f23b accord/cl vtec engines, im pretty sure the Nsx has them. i sure there are alot more than what i listed.
