1.5 block with 1.6 head swap
Old Dec 8, 2006 | 01:53 PM
Fugispeed's Avatar
Default 1.5 block with 1.6 head swap
What is all needed to do this swap timming belt, head gasket etc.
Old Dec 9, 2006 | 11:53 PM
TheBob's Avatar
Default Re: 1.5 block with 1.6 head swap (Fugispeed)
This should help
https://honda-tech.com/zerothread?id=1072933
Old Dec 10, 2006 | 01:43 AM
Redline130's Avatar
Default Re: 1.5 block with 1.6 head swap (TheBob)
It kind of depends on which 1.6 head you are putting on.
Old Dec 10, 2006 | 01:11 PM
Fugispeed's Avatar
Default Re: 1.5 block with 1.6 head swap (Redline130)
i'm using D16Y8 head
Old Dec 10, 2006 | 11:36 PM
Redline130's Avatar
You will need the Y8 headgasket and timing belt. Depending on what ecu you use, you may need to do some wiring work. What chassis is this motor going into?
Old Dec 11, 2006 | 03:12 PM
Fugispeed's Avatar
EK chassis its the original motor in the car has 218,000 miles just want to change it up a little heard u can get really good compresion from the swap will be using the stock ecu P2P now with it being and OBD 1 block will I have any problems with the sensors will I have to swap the sensors over from the OBD II block
EJeff8
12
Oct 3, 2013 08:02 PM
JDM*D
Nov 3, 2008 07:28 PM
biggnubbs
Nov 2, 2005 09:38 AM
CB7DOHC
May 20, 2005 05:55 AM
