00 si cel 72, 73 and 74
Old Aug 7, 2010 | 08:00 PM
jake00si's Avatar
Default 00 si cel 72, 73 and 74
So I started my car up and it sounded like a Harley. Probably because
it was only running on cyl 1. Cyl's 2, 3 and 4 are miss firing. The car has no power right before it died all together. Now it won't even start. My first thought is that some valves are messed up. Any suggestions?
Old Aug 8, 2010 | 12:16 PM
jake00si's Avatar
Default Re: 00 si cel 72, 73 and 74
Compression Test Results
Dry, Wet
Cyl 1. 105, 120
Cyl 2. 110, 132
Cyl 3. 114, 135
Cyl 4. 90, 122
Old Aug 12, 2010 | 08:20 PM
1FASNIGA's Avatar
codes 72 73 74 are random miss fire 2 through 4.... for starters try changing your plugs and plug wires. it could also be your cap or rotor button in the distributor
Old Aug 12, 2010 | 08:22 PM
1FASNIGA's Avatar
also if you change the plugs an wires check the cap an rotor button and see if there good or not.... if so and it still wont start after changing plugs an wires and cap an rotor button are good your ignition coil is possibly no good pull it out and check for hot spots if there is hot spots on it its no good and youll need a new one
RedEJTwo
May 9, 2015 01:11 PM
ludemach23
10
Oct 11, 2009 01:11 PM
EJ8_Enthusiast
Jun 15, 2009 06:02 PM
NOOdS
Feb 13, 2009 02:31 PM
bcumby
Dec 15, 2007 02:36 PM
