Suspension & Brakes Theory, alignment, spring rates....
rear sway bar 99ek
Old 09-14-2017, 02:32 PM
JiNxXx0013's Avatar
Default rear sway bar 99ek
to install a rear sway bar on a 99 ek, all i need is the 2000 si rear sway bar parts? nothing else correct not try to install rear lca or sub frames trying to keep the stock look as close as possible.
Old 09-15-2017, 09:45 AM
ontariorider's Avatar
Default Re: rear sway bar 99ek
For an si sway bar just the bar and endlinks, if you run a bigger swaybar (like a type r) it's suggested u run some kind of a subframe reinforcement brace.
Old 09-16-2017, 12:17 PM
JiNxXx0013's Avatar
ok thanks
Old 09-16-2017, 07:26 PM
Master Detailer
98civdx's Avatar
you will need bigger bolts for the bracket that goes into the subframe, or get the ASR subframe bracket kit.
Ruben19
Suspension & Brakes
05-07-2010 12:56 PM
ekinshuya
05-31-2009 07:36 AM
Tuner Eddy
12-28-2007 04:59 PM
Jchild420
05-20-2004 08:55 PM
Andrew 825SM
07-07-2003 01:19 PM
Quick Reply: rear sway bar 99ek
