Suspension & Brakes Theory, alignment, spring rates....
tein flex vs Function & form coilovers
Old Aug 29, 2007 | 10:41 AM
jdmblackac's Avatar
Default tein flex vs Function & form coilovers
debating on which set up would be better for daily driving .... and track.. which suspension would give you the most of out the system..
Old Aug 29, 2007 | 05:32 PM
jdmblackac's Avatar
anyone??
Old Aug 29, 2007 | 06:15 PM
bmoua's Avatar
for track use....i'd go with GC/koni setup, its basically the same price as for both of the setups you metioned. Also you get 100x more choices on spring rates.
Old Aug 29, 2007 | 10:55 PM
.:Made in OC:.'s Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">for track use....i'd go with GC/koni setup, its basically the same price as for both of the setups you metioned. Also you get 100x more choices on spring rates. </TD></TR></TABLE>
you can get 100x of choices with tein too you know.....
Old Aug 29, 2007 | 11:18 PM
bmoua's Avatar
Default Re: (Made In OC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Made In OC &raquo;</TD></TR><TR><TD CLASS="quote">
you can get 100x of choices with tein too you know.....</TD></TR></TABLE>
but most track/auto-x cars are sitting on GC/koni setups...teins are good but for the money the gc/koni setup dominates. Why do you think so many people use this setup.
Old Aug 30, 2007 | 09:29 AM
AMR Engineering's Avatar
Default Re: (bmoua)
You can easily be competitive with either setup. It truly depends on the setup, as well as your driving. Doesn't matter if you have the best of the best, if it isn't even fitted to what you plan on doing then that will be your downfall. If anything, people should be more concerned on the people who they buy from and their experience with the coilover systems they sell. Rather than just purely brand name. There are a lot of grear coilover companies, GC/Koni/KW/H&R/Tein/Buddy Club, the list goes on. People dominate not due to what coilover they run, that obviously helps, but they dominate because they know how to drive. A good coilover system is the one of the means to become a better driver, and depending on what you plan on doing someone that is knowledgeable should be able to provide you with a setup that will cater to your driving style and experience.
It's kinda like RC car racing, loose is fast. You can have the best RC car in the world, but if you don't practice, and it's not setup for your liking then your not going to dominate. A lot of beginners jump and run the TEAM setup, which is usually a lil loose and they tend to not stay with the standard setup. Standard setup which is made to suit most track conditions and be a good BASE start. But even then the track will determine what will work best, and that is when time and experience comes into play, not what brand shock it runs or etc. But if your good, then you can almost drive anything, even if the car is setup a badly, they just have proper throttle control. People may laugh, but if you ever raced RC cars then you know it ain't no joke either when it comes to suspension tuning. In other words get a system from someone that can get you a good base system to start with that will work well with what you plan on doing and work from there. Good luck!
Old Sep 2, 2007 | 10:19 AM
jdmblackac's Avatar
any one else???
Old Sep 2, 2007 | 04:40 PM
EM1ly's Avatar
Default Re: tein flex vs Function & form coilovers (jdmblackac)
I was in your position too. I had to pick between flex and type 2's. but i went with type 2's. it's really up to you man. good luck
Old Sep 3, 2007 | 08:46 AM
Earl E.Apex's Avatar
Default Re: tein flex vs Function & form coilovers (projectkle)
I'm running Tein flex and they work awesome.
litbulb
May 19, 2012 12:23 AM
Twan
Aug 1, 2006 07:09 AM
BLUE EH3
Suspension & Brakes
27
Oct 23, 2005 01:49 PM
Hoppa
Apr 3, 2004 06:03 PM
TheBlackCrx
Mar 3, 2004 02:24 PM
