Suspension & Brakes Theory, alignment, spring rates....
suspension setup question
Old May 19, 2008 | 05:51 PM
ej6.sean's Avatar
Default suspension setup question
Right now my suspension setup consists of
PIC apex coilovers 12k/10, nrg h-brace,
asr subframe brace with 24mm swaybar, f7 lcas
and skunk2 front/rear camber kit other than better tires and brakes
i still feel like a get a little body roll around turns or maybe its my tires
would i see anything else with getting front/rear strut bars and a front sway bar?
Old May 19, 2008 | 08:26 PM
Targa250R's Avatar
be professional
Default Re: suspension setup question (ej6.sean)
You do realize that eliminating body roll isn't the goal of modifying suspension, right?
Old May 19, 2008 | 09:45 PM
TotalBalance's Avatar
front sway bar
that doesn't the body roll will disappear. Will decrease however, but won't disappear.
For the strut bars, they will not make ur car to roll less, but make handling input more rigid. Strut bar is there to make ur car's body more rigid. In racing world, they do this properly by welding their car in numerous locations. think of strut bar as poor man's body reinforcement. that's why people saying strut bar is not doing much becaues you won't feel that much of difference. But for me, strut bar is a must have option.
Old May 20, 2008 | 06:17 AM
bsclywilly's Avatar
Default Re: suspension setup question (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You do realize that eliminating body roll isn't the goal of modifying suspension, right?</TD></TR></TABLE>
Are you sure about that?
Old May 20, 2008 | 09:35 AM
Targa250R's Avatar
be professional
Default Re: suspension setup question (bsclywilly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsclywilly &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure about that?</TD></TR></TABLE>
What do you think the purpose is?
Old May 20, 2008 | 05:28 PM
ej6.sean's Avatar
hmm thanks for the input, what front sway bars you guys running?
Old May 20, 2008 | 05:48 PM
TunerN00b's Avatar
Default Re: (ej6.sean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6.sean &raquo;</TD></TR><TR><TD CLASS="quote">hmm thanks for the input, what front sway bars you guys running?</TD></TR></TABLE>
For most of us (those that value traction), the smallest bar we could find (or no front bar at all). I'm still using the stock 24mm GSR front bar, but would love to upgrade to a nice 19mm (I believe thats the smallest OEM bar that fits a DC2 chassis).
Now, the rear of the car is an entirely different story. I'm almost ready to mount a chain link fence post back there, cause even my Comptech 22mm set to the stiffest setting ain't cutting it.
Old May 20, 2008 | 06:14 PM
ej6.sean's Avatar
could i use one from a coupe? my car is dx ek hatch and doesnt come with one..
Old May 21, 2008 | 01:36 PM
yes you can use one from coupe, sedan or watever as long as it is from 96-00 civic. your car is 96-00 hatch right? then ya.
even ITR will fit on 96-00 civic, as long as you have front LCAs from one of the non-si civic with stock sway in front.
I am running 26mm front 22mm rear both from CTR. The front sway from SI is same as the one from CTR. I love how it handles
I dont recommend people to run sway bar only on the rear. It would logically make car turn better with making oversteer. However, IMO, turning the car is depends on the grip of front tires, meaning the front half of the car should be rigid so it can withstand the flex/twist watever you want to call it.
Running only with rear will hop the front and result in understeer. Decent tires with proper front&rear swaybar + coilover setup (ie height difference front and rear, spring rates, strength of damping) would make car handle much better.
it is all about total balance
Old May 21, 2008 | 02:19 PM
ej6.sean's Avatar
thanks for the input ill look into getting a front sway bar
Old May 21, 2008 | 03:50 PM
dont forget you have to get right front LCA with swaybar you are getting.
ie SI front LCA + SI sway bar + SI shock forks
or
EX front LCA + EX Sway bar + your stock shock forks
Old May 22, 2008 | 06:53 PM
ej6.sean's Avatar
Default Re: (TotalBalance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TotalBalance &raquo;</TD></TR><TR><TD CLASS="quote">dont forget you have to get right front LCA with swaybar you are getting.
or
EX front LCA + EX Sway bar + your stock shock forks</TD></TR></TABLE>
thanks bro
TheRookie74
Aug 11, 2014 10:02 AM
eternity0
Suspension & Brakes
May 9, 2006 11:53 AM
_Bug_
Suspension & Brakes
11
Mar 3, 2006 12:40 AM
Ass_Clown
Sep 13, 2002 06:44 PM
willyboyK20
Jan 20, 2002 12:09 AM
