suspension problem!
Alright so I have a 94 del sol si. I swapped b16 in it and used ek spiindles.the only reason I used them was cu del sol didn't have any when I bought. The problem was that ek spindles were bent because the ek was totaled and suspensio bent. But I still put on anyways....car ran ok but would jerk to right really bad. Went and got it aligned and they said they could try to align but they straightened out steering wheel but still jerked to right. The other day I was racing and I snapped my axle so I replaced and alignment was off again....then I raced two days later and now wheels kinda lock up sometimes and car will stutter. It isn't a motor or tranny problem..... cuz I jacked car. Up and ran through every gear and ran fine. When I push car it does it too....it only does it when car is accelerating and not when decellerating. And does it when I drive straight and worse when I turn. Could screwed up spindles have caused some other suspension partsa to mess up? And what other spindles can I use on my delsol with the ek brakes?
Sounds like you need new spindles and possibly some new calipers as it really hard for something else to lock up a wheel except for a caliper.
By ek brakes do you mean base model EK or EX/Si EK?? Either way, there are corresponding spindles from an EG/DC that will fit those brakes AND will give you the proper suspension geometry
real human VTEC
26
Sep 2, 2005 04:50 AM
