Setup questions
I have a semi stock EH3 with a b series..
I currently have skunk2 coilovers on agx adjustables and a full ES bushing kit. I have the stock Si (21mm) sway bar, and have been also using ST front and rear sways. I felt I had too much understeer at high speeds so I sold the ST kit.
My subframe had a broken bolt on the inside of the frame, so I swapped it out with an ITR subframe and rack.
-I also have the ITR 26mm front swaybar that came with the subframe.
-I also have a set of (used) Koni yellows that I got from a friend.
-I plan on getting a Blox 22mm rear sway and ASR subframe brace.
So heres my questions...
How will my handle if I:
-Use the 26mm front w/ 22mm rear, AND use the skunk2/agx setup I have now.
-Use the 26mm front w/ 22mm rear, AND use the S2 sleeves w/ Yellows.
-Use the stock 21mm front w/ 22 mm rear, AND use the s2/agx setup.
-Use the stock 21mm front w/ 22 mm rear, AND use the s2/yellows.
turbotime
Apr 18, 2005 10:13 PM
nonsense
Suspension & Brakes
10
Jan 12, 2005 04:09 PM
