Suspension & Brakes Theory, alignment, spring rates....
quick question with disc conversion
Old Feb 8, 2015 | 05:06 AM
dlx111's Avatar
Default quick question with disc conversion
Have an eg just got a rear disc setup but no rotors, calipers, cables, and I've searched but not sure if I'm missing anything for the install.
I know I need caliper brackets and semi loaded calipers cus Im going to put in stoptech pads, e brake cables and rotors obviously, but am I missing anything else small? Thanks
Old Feb 8, 2015 | 01:35 PM
Bently_Coop's Avatar
Steve at Heart
Do you have soft brake lines from the caliper to the chassis? Might be a good time to upgrade to stainless braided lines.
Old Feb 9, 2015 | 02:44 PM
egsleepercivic's Avatar
Default Re: quick question with disc conversion
proportioning valve?
Old Feb 10, 2015 | 10:03 AM
apexapexapex's Avatar
bushings on the trailing arm
Old Feb 14, 2015 | 03:33 PM
dlx111's Avatar
I actually have all that sorted but now im kind of confused on the ebrake cables. Ive been reading that alot of the integra cables are too long and dont pull hard like they should because theyre too long. Looking on Rockauto the teg hatchs cables are 64" and the ones for my coupe are 61". Someone said to get abs cables of my year but those are listed as 65"...so im confused lol.
Old Feb 15, 2015 | 01:15 PM
Tkrizz's Avatar
Get 92-95 EX coupe cables and it will work.
Old Feb 15, 2015 | 05:52 PM
if you have a hatch get the cables for a 92-95 si
if you have a coupe get ex cables with disk brakes
Old Mar 25, 2015 | 06:32 AM
gmcuajo1's Avatar
What the 2525, 3030, 4040 of proportioning valve means?
The percentage of braking pressoure/power going to the rear?
Old Mar 25, 2015 | 09:48 AM
spAdam's Avatar
Loved
Community Favorite
Correct. Get the cables for the chassis (disc version, obviously), not the brakes. Civic sedan/coupe are the same.
Skip the Rockauto cables and spend the extra $20 on Honda ones. Trust me on this, I'm speaking from an annoying experience.
Whatislove
Honda Civic (2001 - 2005)
12
Nov 9, 2010 06:59 AM
ShreqBoi
Mar 16, 2010 06:08 PM
EJ1chevelle
13
Aug 17, 2007 10:52 PM
jus_spooln_wicha
May 14, 2007 12:40 AM
