Suspension & Brakes Theory, alignment, spring rates....
question about preload
Old May 6, 2012 | 04:10 PM
swizz977's Avatar
Default question about preload
ok so my car is tucking a 195/50/15 2000 civic.. on tein flex.. sometimes i hit my headers over bigger dips.. my question is if i put more preload will the suspension have less travel thus giving me a less chance of hitting my header??
Old May 6, 2012 | 04:57 PM
grumblemarc's Avatar
The Grumpiest
Default Re: question about preload
No.
Old May 6, 2012 | 06:42 PM
swizz977's Avatar
please can you just ignore my threads you are not helpfull at all..
Old May 6, 2012 | 06:51 PM
Dc4LsTeG's Avatar
EK9
How is he not helpful? He answered your question
Old May 6, 2012 | 07:58 PM
swizz977's Avatar
with no explination
Old May 6, 2012 | 08:49 PM
Tyson's Avatar
no, you need to raise your ride height.
Old May 6, 2012 | 09:24 PM
GagnarTheUnruly's Avatar
As grumblemarc indicated preload doesn't affect spring rate. Follow Tyson's advice or get stiffer springs.
Old May 7, 2012 | 05:49 AM
swizz977's Avatar
so what does increasing the preload do then??
Old May 7, 2012 | 05:56 AM
swizz977's Avatar
the springrate on teins page says 9/504
Old May 7, 2012 | 09:57 AM
98civdx's Avatar
Master Detailer
Nothing.
Post a picture of how the car sits.
Old May 7, 2012 | 11:50 AM
swizz977's Avatar
tadaa
Old May 7, 2012 | 12:50 PM
98civdx's Avatar
Master Detailer
Avoid big dips
Old May 7, 2012 | 03:21 PM
GearHeadDeals.com's Avatar
Originally Posted by 98civdx
Nothing.
This is not true.
Preload will in effect increase static ride height. It also increases the amount of force needed to begin spring compression (which raising the threaded body/ride height alone will not do). So yes it could help you avoid hitting the header. Just make sure there is no chance the coil binds before the bumpstop is compressed. You don't want your suspension stop to be the spring.
Old May 7, 2012 | 03:24 PM
swizz977's Avatar
Originally Posted by GearHeadDeals.com
This is not true.
how do i make sure the coil wont bind before the bumpstop is compressed
Old May 7, 2012 | 03:28 PM
get a ruler out and measure. if calculated collapsed coil height > exposed damper rod length then you would have a problem.
it's very unlikely this will happen though so I wouldn't worry about it.
I should clarify that this::
Is cause by this:
I will also make clear that the point of changing preload is to alter the ratio of compression travel/rebound travel(droop). Ideally the ride height should be altered through the threaded body in your case. If you need more, then turn up the collar and increase preload.
Old May 7, 2012 | 04:17 PM
TunerN00b's Avatar
You know, you could also try running the correct tire size, instead of tires too small in diameter. Doing so would raise the car slightly and decrease the fender gap.
swizz977
Suspension & Brakes
Sep 9, 2012 11:49 AM
EJ1_CRIS_909
Suspension & Brakes
12
Aug 23, 2011 10:09 AM
BETNCORT
Suspension & Brakes
Jun 6, 2005 10:41 PM
HondaCutter
Jan 26, 2004 08:28 AM
DiPPeD iN miLk Ej CoUpE
Jun 28, 2003 08:34 PM
