Suspension & Brakes Theory, alignment, spring rates....
LCA question ????
Old May 14, 2006 | 04:52 PM
pynikal's Avatar
Default LCA question ????
what exactly do aftermarkey lcas do for you?? i replaced mine with omnis becuase bolt seized up and had to replace. didnt notice any diff.
Old May 14, 2006 | 05:04 PM
kaiba's Avatar
Default Re: LCA question ???? (pynikal)
The only thing you should notice is the bling bling.
Old May 14, 2006 | 05:21 PM
pynikal's Avatar
Default Re: LCA question ???? (kaiba)
thats all huh. kind of a let down. but bling is cool.....i guess
Old May 14, 2006 | 05:35 PM
Voyage34's Avatar
they save *tiny* bit of weight- ~1-2lbs per corner.
also if the bushings in your current lcas are worn you might get some benefit from new bushings
but yeah, bling...
Old May 14, 2006 | 07:03 PM
PIC Performance's Avatar
Other than adding a mounting point for a swaybar (if your stockers don't come with one), then there's not much in the physical design that can benefit performance.
However the bushings are a different story. You'll notice a difference between good and bad bushings, in that good bushings will last and do their job, while bad bushings will crack, deform, and fall apart in an unreasonably short period of time.
Upgrading to a stiffer material for the bushings will generally yield better handling as well.
Old May 14, 2006 | 07:05 PM
pynikal's Avatar
Default Re: LCA question ???? (PIC Performance)
thanx for all the info on this guys
Old May 15, 2006 | 07:54 PM
EG2Driver's Avatar
speaking of which.....do you need longer bolts for the sway bars to fit with the omni power rear LCA?
thenext
Oct 18, 2011 02:12 PM
EgonzEk
Apr 12, 2011 03:03 AM
Historyg
Sep 14, 2007 04:44 PM
Nothing.Special
Suspension & Brakes
May 23, 2005 09:47 AM
