!!!LCA bushing problem....
Simple. I bought a set of AMR dampers for a 98 civic, trying to install but the rear lower control arm bushing on my 98 Integra is bigger than the civic. The only option i have is basically buy 96-00 civic rear LCA bushing correct? and have them pressed onto my 98 integra LCA's...? Even if i order aftermarket LCA's id still have to get the bushing for the civic right?
If you bought LCA's for a 96-00 Civic, the shock bushing would be the least of your worries. If you have the tools, you can shave off 5mm from each side of the bushing to accommodate the coilover's narrower fork.
HERN39
Jan 21, 2014 12:15 PM
Civicboy
Apr 10, 2005 06:43 PM
