i need help with height difference from front to back
i have more then a 4 inch gap in the front but in the back its only a little more then 2 inches...
with lowering springs that do 2"/2" it would still have a 2" front gap
with coilovers i could lower it 4"/2" but id have to live with the ride quality of coilovers....
is there any way to even out the front so i can just use the springs or something?
no aftermarket part is on yet...i was wondering what would lower 4" front/2" back....but still remain comfortable..
the reason for the back being lower then the front is the fact that the sub enclosure takes up the entire trunk...quite heavy
Sorry, I misunderstood what you were saying. Possibly you could just get a set of coilovers with a higher spring rate in the rear??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA »</TD></TR><TR><TD CLASS="quote">Sorry, I misunderstood what you were saying. Possibly you could just get a set of coilovers with a higher spring rate in the rear??
It helps to tell us what car you have.
If it's a Civic or Integra, you could get Koni Sport shocks along with a lowering spring of your choice and then set the rear spring perch higher to keep the rear end from sagging.
I think the Koni shocks for the Accord have similar provisions for height adjustment, but I'm not totally sure.
