Suspension & Brakes Theory, alignment, spring rates....
4x114.3 integra type r brake rotors
Old 07-07-2005, 09:46 PM
gsrious's Avatar
Default 4x114.3 integra type r brake rotors
i need some info as to which conventional brake rotor(accord and prelude) i can get to change out my 4x114.3 brake rotors.
my type r rotors are wearing out on me... the surface area is way too distorted to resurface.
i would like to know if i can purchase an accord or prelude rotor in the 4x114.3 spec to just change it.
Old 07-09-2005, 10:00 PM
Kevedge's Avatar
Default Re: 4x114.3 integra type r brake rotors (gsrious)
92 si non vtec prelude rotors but you have to space the caliper from the hub
/thread
Old 09-01-2005, 08:48 AM
John in NorCal's Avatar
back from the dead..cause i have the same problem
...how do you space the caliper from the hub?
...if anything i have heard all i have to do is buy GSR rotors and just have them re-drilled to 4x114...i am just trying to find the easiest solution. thanks
Old 09-02-2005, 11:35 AM
. o 69 o .'s Avatar
Default Re: 4x114.3 integra type r brake rotors (John in NorCal)
you can also upgrade to 92-96 prelude vtec 11" rotors...
all you need is the Prelude calipers, pads, backets and rotors..
Put a 2mm spacer between the bracket and the spindle, that eliminates the clearance issue mentioned above... bolt the rest up, re-bleed the brakes, good to go.
Also.. if you ever need to replace the front wheel bearings, you can use 2001 civic front wheel bearings. I did mine about a month ago. I just have to figure out which ones for the rear
PM me if you have any questions
Old 09-02-2005, 09:45 PM
KOALA YUMMIES's Avatar
Default Re: 4x114.3 integra type r brake rotors (Kevedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevedge &raquo;</TD></TR><TR><TD CLASS="quote">92 si non vtec prelude rotors but you have to space the caliper from the hub
/thread</TD></TR></TABLE>
LOL!
Old 09-03-2005, 06:01 PM
itrsleeper's Avatar
get 86-87 acura legend rotors, i had the same prob the day before track day. you might have to shim the rotors with some large washers (in between rotor and hub) because the stick out further away from the hub than the stock ones and so they wont rub on you r calipers.
Old 09-03-2005, 11:46 PM
we are j's tunning car maniax!
jdmtheory.com's Avatar
Location: New Used Japanese OEM Aftermarket Parts, San Francisco, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">i need some info as to which conventional brake rotor(accord and prelude) i can get to change out my 4x114.3 brake rotors.
i would like to know if i can purchase an accord or prelude rotor in the 4x114.3 spec to just change it.</TD></TR></TABLE>
I can order you the 4x114.3 rotors brand new from Japan.
Old 09-04-2005, 12:24 PM
itrsleeper's Avatar
Default Re: 4x114.3 integra type r brake rotors (jdmtheory.com)
can you get all 4?? for 96 spec itrs?? please lemme know!
Old 09-04-2005, 12:58 PM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmtheory.com &raquo;</TD></TR><TR><TD CLASS="quote">
I can order you the 4x114.3 rotors brand new from Japan. </TD></TR></TABLE>
pm me some info.
Old 09-11-2005, 12:16 AM
KhanhCord's Avatar
hmmm j/w why do they HAVE to be JDM? the 94 - 02 accords(i4) have 4x114.3
Old 09-11-2005, 11:31 AM
ShiroX's Avatar
Default Re: 4x114.3 integra type r brake rotors (KhanhCord)
the rotor hat has a different offset
Old 09-11-2005, 03:43 PM
itrsleeper's Avatar
because the accord 4x114.3 are an 11 inch rotor, andthe 96 spec itr are i believe 9.25 and they wont fit with the 96 spec calipers, thats why the have to be jdm. or atleast with the same diameter and offset.
Old 09-15-2005, 01:19 AM
KhanhCord's Avatar
Default Re: 4x114.3 integra type r brake rotors (itrsleeper)
cant u upgrade urs to 11" ?
again, why did u switch to 4x 114 instead of 4x100? was it cuz of rims option?
sry for the n00b Qs...just wana know the concept behind this..
-Thz
Old 09-15-2005, 06:24 AM
itrsleeper's Avatar
you can upgrade to 11" but you need the 98 spec caliper or the prelude caliper to run the larger rotors, and you can even rut the nsx caliper but with shims. i did it cause i got a good deal on the whole package, but now its a pain in the *** trying to find replacement rotors. i dont see to many civics with 96 spec itr rims, so its kinda rare.
Old 10-06-2005, 08:53 AM
egtype-r's Avatar
here is everything you need cause i have never found direct answers from any other thread
if your going to keep everything stock and not upgrade calipers these are the parts you need
the calipers are from a 94-97 gsr
the pads are from a 94-97 gsr
brake lines 94+ gsr
rotors 92-96 si non vtec space the caliper how the guy mentioned above
e brake cables i havent confirmed but i believe 2000 civic si
any other questions pm me
Old 10-09-2005, 11:03 AM
xsellxoutx's Avatar
Default Re: 4x114.3 integra type r brake rotors (egtype-r)
so washers between the rotor and the hub or between the caliper braket and the knuckle?
Old 10-09-2005, 06:08 PM
. o 69 o .'s Avatar
Default Re: 4x114.3 integra type r brake rotors (xsellxoutx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx &raquo;</TD></TR><TR><TD CLASS="quote">so washers between the caliper braket and the knuckle?</TD></TR></TABLE>
BINGO
Old 10-10-2005, 02:36 AM
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: 4x114.3 integra type r brake rotors (B16B)
just get GSR's adn redrill them to 4x114 any machine shop can do it EASY!
Old 10-10-2005, 05:27 PM
egtype-r's Avatar
Default Re: 4x114.3 integra type r brake rotors (Snoflake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake &raquo;</TD></TR><TR><TD CLASS="quote">just get GSR's adn redrill them to 4x114 any machine shop can do it EASY! </TD></TR></TABLE>
i heard it weakens the rotor and makes them prone to cracking
Old 10-10-2005, 07:06 PM
itrsleeper's Avatar
the question still remains, does any one know how to get oem jdm rotors?? i have been emailing every suposed "jdm" shops to see if they can order them but i havent gotten any replies or even gotten a couple of off the wall answers like "use accord ones"
has any one successfully replaced the rear set of 4x114.3?? any help would be appreciated.
Old 10-10-2005, 08:25 PM
Munkyw3rkz.webs.com
S@nt0s's Avatar
i recently sold Brand NEW SPOON (oem) rotors 4x114........
but u should be able to get them from spoon, look into a spoon authorized dealer
Old 10-13-2005, 04:17 PM
itrsleeper's Avatar
but doesnt japan have there own version of autozone or pepboys?? thats really all i am looking for. where do the japanese guys get there remanufactured oem parts from??
Old 10-17-2005, 07:01 AM
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: (fridexter)
trust me get GSR's redrill them, i wouldnt worry aboutthe quote on quote crackin because you are goign to be road racing it so it isnt goign to be under high operating temps......
Old 10-17-2005, 09:42 AM
. o 69 o .'s Avatar
Default Re: (Snoflake)
convert the front to 11" prelude... OEM supremacy
Old 10-17-2005, 06:08 PM
itrsleeper's Avatar
Default Re: (B16B)
im not going to get gsr and redrill them, because as often as i warp stock ones i dont want to risk them cracking. plus whats the point of buying a new set of rotors and calipers after already upgrading?? if i can find a place to get jdm rotors then my problem is solved. so far the 86-87 acura legend rotors have been the right size, just not strong enough. plus having shim them dosent make me feel better.
so no one knows where to get remanufactured or even oem jdm 96 spec itr rotors?? (4x114.3 lug pattern witha 9.25 diameter)
Quick Reply: 4x114.3 integra type r brake rotors
