Suspension & Brakes Theory, alignment, spring rates....
Ground control top hat problem
Old May 28, 2006 | 02:00 AM
super_nguyen's Avatar
Default Ground control top hat problem
has this happened to anyone else? i went to install my suspension (ground controls and konis) and when i was bolting the top hat on, one of the bolts that are pressed into the top hat came loose, and now it spins freely and i can't get the bolt to tighten. does anyone know if their lifetime warranty includes their top hats?
Old May 30, 2006 | 05:44 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ground control top hat problem (super_nguyen)
Which bolt? I had no problems with mine, but if it is broken, GC should replace it.
Old May 30, 2006 | 07:41 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Ground control top hat problem (JDM_Ej)
I imagine he's refering to one of the two pressed-in mounting studs that attaches the entire shock assebly to the chassis. If one of those came loose, you should definently contact GC right away. To get it off, you may have to cut through the stud, or drill it out.
I guess the easiest thing would be to take a dremel & cut a screwdriver slot in the top of the stud. Then hold the stud steady with a flathead screwdriver while you turn the nut off with a wrench.
Old May 30, 2006 | 12:29 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">has this happened to anyone else? i went to install my suspension (ground controls and konis) and when i was bolting the top hat on, one of the bolts that are pressed into the top hat came loose, and now it spins freely and i can't get the bolt to tighten. does anyone know if their lifetime warranty includes their top hats?</TD></TR></TABLE>
I had the exact same problem.
Simple solution for me was to install the entire shock, spring, tophat assembly into the car without the nuts that mount the tophats to the inner fender, and drop the car onto the wheels. The pressure from the springs were enough to keep the bolts from turning as I torqued the nuts down.
Old May 30, 2006 | 02:02 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Ground control top hat problem (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">I had the exact same problem.
Simple solution for me was to install the entire shock, spring, tophat assembly into the car without the nuts that mount the tophats to the inner fender, and drop the car onto the wheels. The pressure from the springs were enough to keep the bolts from turning as I torqued the nuts down.</TD></TR></TABLE>
Thats how your supposed to install those nuts anyways (per honda service manual)...
JDM_Ej
Suspension & Brakes
22
Dec 16, 2011 08:20 AM
Xathine
Suspension & Brakes
Nov 6, 2008 12:51 PM
EL'ation
Jun 10, 2005 05:05 AM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
5spdIntegra
Nov 28, 2004 06:11 PM
