ground control problem
Hey guys i have a 99 si with a agx ground control setup on it, the only problem i have with this setup is that the rear sleeves are too short and do not allow enough adjustement for me to raise the car up to the height that i need it to be at. i already have them fuklly maxed out and my camber it about -3.5 degrees lol. so cutting to the point i was wondering where i would be able to buy just the sleeves for the ground controls?
thanks for your help in advance
are the front sleeves longer than the rears? Maybe you can swap the sleeves so you have more adjustment room on the rear.
also, you might need longer rear springs. what size do you have now?
Project Phoenix
Honda CR-V & Element
35
Jan 30, 2015 06:38 PM
