Suspension & Brakes Theory, alignment, spring rates....
full bleed needed?
Old Feb 21, 2010 | 09:50 PM
munky69's Avatar
Default full bleed needed?
if i just replace the front calipers and that's it, is it really necessary to bleed all 4 corners? .. i searched and couldn't find a for sure answer. thanx for any info
Old Feb 22, 2010 | 06:20 AM
roastbeefrichie's Avatar
Default Re: full bleed needed?
whenever you introduce air to to the system (by removing brake hose or replacing caliper) you must bleed your brakes.
Originally Posted by BrakeExpert
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
Old Mar 10, 2010 | 08:13 AM
it is necessary to bleed all 4 calipers
(bleeding sequence: Right Rear, Left Front, Left Rear, Right Front)
just bleeding the fronts will cause the air to be trapped in the system
Old Mar 24, 2010 | 04:13 PM
munky69's Avatar
i didn't have any problems. but ended up with a cut in one of my lines and ended up bleeding all 4 anyway a few weeks later. like i said tho, might as well bleed all four, but i got lucky and didnt have to that time
Old Mar 30, 2010 | 04:17 PM
djhotwheel's Avatar
Any tricks we should know about bleeding?
black0hatch
Jan 22, 2008 05:08 PM
full Circling
Jul 12, 2004 06:12 AM
extrmeboost
Apr 9, 2003 01:00 AM
Osman
Nov 18, 2002 01:26 PM
Kamin
17
Jun 25, 2002 12:38 PM
