Front Strut How To Writeup
remove.
2 top nuts.
1 bolt/nut in the lower fork.
if stock should have a bracket for the brake line. remove bolts if that is the case.
loosen.
1 bolt on fork that holds damper.
2 top nuts.
loosen.
2001 EX is Macpherson.
Remove the two lower strut bolts.
Support the LCA/kunckle so it doesn't swing down and pull the CV joint apart inside the boot.
Remove the ABS wires and brake hose from the strut but don't remove them from the car.
Remove the top nuts from inside engine bay.
Drop the strut assembly.
98slvrcx
20
Aug 25, 2002 10:16 AM
Kasper.
17
Jun 29, 2002 10:04 AM
