Suspension & Brakes Theory, alignment, spring rates....
EF spring help needed.
Old Apr 16, 2015 | 09:31 AM
1320london's Avatar
Default EF spring help needed.
ok so i abought some tein springs for my 91 crx and put them on the rear 2 are on koni shocks the front are stock shocks, the drivers sidesits fine however the passenger side rubs in the back really bad and the front looks a lil higher to me.
im not sure if it is due to me doing something wrong or leaving something out, any help would be appreciated.
Old Apr 16, 2015 | 11:10 AM
jlk16188's Avatar
Default Re: EF spring help needed.
are you sure you put the front springs on the front and the rear springs on the rear and not visa versa?
Old Apr 16, 2015 | 11:27 AM
1320london's Avatar
yea i already made that mistake once before.
Old Apr 16, 2015 | 03:59 PM
Tyson's Avatar
that passenger wheel is not sitting correctly. has nothing to do with the shocks or springs.
id be looking for bent control arms and stretched radius rod and bent crossmember.
Old Apr 17, 2015 | 10:37 AM
1320london's Avatar
how do i go bout fixing the radius rod.
Old Apr 17, 2015 | 10:41 AM
jlk16188's Avatar
looks to me as though you forgot the washers or put them in wrong on the tophats. Doesnt look like the suspension is holding the car up at all. Ive never seen Tein springs that low. It also looks like your pass wheel is pushed very far backward. Jack up that side and make sure you bolted everything up right.
These ares are very simple so you messed up somewhere putting this all together
Old Apr 17, 2015 | 11:38 AM
1320london's Avatar
i think i put a washer in the wrong place on the struts and the radius rod dosent look right but idk how to adjust it.
Old Apr 17, 2015 | 06:37 PM
KevinEF7's Avatar
Passenger side suspension is way messed up, and your tire and rim size is much bigger than stock
Let me guess, no money for an alignment
Old Apr 17, 2015 | 09:20 PM
1320london's Avatar
the shocks dont rebound when they go downwhat would cause that.and the car hasnt been on the street in awhile it will get an alignment soon.
Old Apr 18, 2015 | 10:25 AM
1320london's Avatar
does the top hats make a difference if there swapped around, i didnt think they did so i might of mixed them up
lngel
Suspension & Brakes
Aug 6, 2015 07:36 PM
CRX-1991
Jan 26, 2008 08:20 PM
EFresh
Suspension & Brakes
10
Jul 25, 2006 01:43 PM
PearlWhiteAccord
Jun 3, 2002 09:21 AM
