Suspension & Brakes Theory, alignment, spring rates....
coilover sleeve?
Old Mar 21, 2006 | 06:07 PM
VeilSide_Mas's Avatar
Default coilover sleeve?
I'm just wondering how good are those tenzo-r coilover sleeve and skunk2 coilover sleeve? comparing it with just H&R lowering springs , which handles better for budget race use?
thanks
Old Mar 21, 2006 | 11:02 PM
ttt
no one have an opinion? i would just like to see would people go with a better handling spring or lower rides crappy handling looks.....
Old Mar 21, 2006 | 11:19 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (VeilSide_Mas)
If you cheap out on suspension, it will **** you off to no end.
As far as the coilover sleeves go, they are mostly junk. The ONLY kind that are worth it are Ground Controls. They aren't too expensive, and you can get custom spring rates as well.
Old Mar 22, 2006 | 10:46 AM
why i see seldom people opt for lowering springs? do they handle just as bad?
Old Mar 22, 2006 | 10:58 AM
CRR 2's Avatar
If your main concern is a nice comfortable ride go with lowering springs with some decent shocks/struts. If you want ablity to adjust height whenever and dont mind a little stiffer ride go with a good set of coilovers and a good set of shocks/struts. also if you are going to race definetly go with coilover set up . something like gc with koni yellows, tein ,jic or omni. Just my opinion though
Old Mar 27, 2006 | 10:00 AM
myrevenge's Avatar
Default Re: coilover sleeve? (VeilSide_Mas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeilSide_Mas &raquo;</TD></TR><TR><TD CLASS="quote">I'm just wondering how good are those tenzo-r coilover sleeve and skunk2 coilover sleeve? comparing it with just H&R lowering springs , which handles better for budget race use?</TD></TR></TABLE>
the problem your going to run into is that your lowering springs willnot sit on the perch of the sleeves correctly, the sleeves and perches are desined for a very spicific spring, and although they make actully work till you get to the end of your block, you will die a misrable, horible, bloody death if you catch a pot-hole on the freeway!
if your on a tight budget (which is just STUPID when modifying suspension, i mean its only the saftly and wellbeing of yourself, and other people on the road were talking about) BUT IF YOU MUST, and your on a tight budget, opt for a coilover conversion, most reputable companys will give you everything you need, sleeves, perchs, springs with the correct tension rate, that are desined for what your attempting to use them for, bumpstops, upper mounts, ect... NORMALY in the price range of about 325 chickens! those along with new shocks (even cheap OEM replacments will do for a while) will give you a night and day diffrence between anything your gonna peice together, and;
OH GOD!!!! NOOOO!!! PLEASE, on behalf of all of honda-tech... for the love of your own ***... DONT CUT THE SPRINGS!!!!
RiceBurnerRebel
Suspension & Brakes
Apr 4, 2014 07:00 AM
cmiller219
Aug 22, 2007 10:20 AM
dom5372
Suspension & Brakes
Nov 16, 2005 11:44 AM
theslugbug
May 31, 2004 08:47 AM
501 Lude
Jun 20, 2003 05:07 AM
