Suspension & Brakes Theory, alignment, spring rates....
Coilover Recommendations for Street Use
Old Mar 20, 2021 | 02:45 PM
ZimbuVTi's Avatar
Icon5 Coilover Recommendations for Street Use
Currently have my EG4 hatch on Cobra lowering springs and wish to replace them with coilovers. Mainly want control over the ride height as its a bit too low and the roads in my country are trash for a super lowered car.
Been looking at brands such as Progress and Tein but still a bit uncertain. The car will see general use and the odd hillclimb guest run so not looking for race-spec coilovers by any means.
Any suggestions would be highly appreciated. (Also living in Europe)
Old Mar 21, 2021 | 12:36 PM
mr_manny's Avatar
Default Re: Coilover Recommendations for Street Use
I heard mixed reviews with Tein.
Once my suspension is need of replacement...will probably go with BC Racing.
Old Mar 21, 2021 | 02:56 PM
Stopsign32v's Avatar
Loved
Can't say enough good about my Tein Flex. Much better than the out of box Koni/GC I used to have.
Old Mar 21, 2021 | 03:38 PM
mr_manny's Avatar
The other nice thing about BC racing, is that you can order replacement parts down the road.
Not all suspension companies offer Individual dampers, springs, etc.
I am not affiliated in anyway with BC racing
Old Mar 22, 2021 | 09:15 AM
Tyson's Avatar
progress CS2 is a pretty great value.
Old Mar 22, 2021 | 01:54 PM
ZimbuVTi's Avatar
Thanks for all the recommendation lads. I was looking at these HSD Dualtech coils recently. They look like a good value and pretty good quality with a decent amount of adjustments available.
What I'm concerned about is Fork/Eyelet type of LCA, do coilovers need to be specially designed or can they be interchanged?
Old Mar 22, 2021 | 01:58 PM
Tyson's Avatar
the rear control arms can be changed. geometry is the same. not all OEM control arms have swaybar mounting available, if that matters to you.
are you in the UK? i guess its better to get whatevers local to your region.
Old Mar 22, 2021 | 02:16 PM
ZimbuVTi's Avatar
I'm from Malta and the car is the JDM variant. From what I've seen they have the eyelet LCA's so must as well just buy a coilover kit set up for those kind of mounts.
Old Mar 22, 2021 | 02:18 PM
Tyson's Avatar
like i said, doesnt matter if you get the matching LCA, or get a compatible shock. up to you.
ls_all_motor#97
Suspension & Brakes
Jul 25, 2008 02:02 PM
reboosted
Suspension & Brakes
Apr 6, 2008 02:38 PM
TurboSam
Suspension & Brakes
Sep 27, 2005 06:16 PM
1JDMDOMINICAN
Dec 11, 2004 06:50 AM
