Camber kit adjusted...steerings weird though??
my hatchback has powersteering still i recently adjusted my camber kit cause tires kept rubbing no more rubbing but steering is weird car reacts to my steering more but the steering wheel turns to quick dont really know what it is if its a good thing or not...also does that mean im in need of an alignment
Re: Camber kit adjusted...steerings weird though??
I'm guessing you added negative camber (moved the camber kit inwards) to keep the tires from rubbing. What you have done now is introduced toe in on the front end of the car. Toe in can generally help keep a car going in a straight line better, but usually isn't that great for cornering performance. Also you have no idea what sort of camber angles you have now, or what toe angles you have. I'm sure everything is different side-to-side.
You really need to get it on an alignment rack ASAP.
JDMhatchback20
11-17-2004 09:06 PM
