Suspension & Brakes Theory, alignment, spring rates....
car pulling left.
Old Sep 5, 2007 | 05:40 AM
D_TY3's Avatar
Default car pulling left.
hey guys i have an 01 accord
the car recently started pulling left.
initially i thought it was the alignment, so i went ahaed and got it done.
the car is still pulling left....
can anyone give me a suggestion on whats going on?
also, the rear sway bar endling is broken (passenger side) but i dont believe this would cause that, would it?
thanks in advance....
Old Sep 5, 2007 | 10:25 AM
PIC Performance's Avatar
Default Re: car pulling left. (D_TY3)
no the broken endlink would not cause your problem.
What condition are your tires in? Under what conditions does it pull to the left? And what were your final alignment specs?
Old Sep 5, 2007 | 10:55 AM
hatchling37's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">What condition are your tires in? Under what conditions does it pull to the left? And what were your final alignment specs?</TD></TR></TABLE>Yes, you can have what's called a 'radial pull' where you one be able to see that a cord has slipped in a tire, but it can cause a pull or drift.
You also might have alignment numbers that are within factory spec, so they won't wear tires adversely, but they can line up improperly and cause a pull.
Old Sep 5, 2007 | 12:55 PM
D_TY3's Avatar
Default Re: car pulling left. (hatchling37)
i dont have the specs on hand but, i actually had them do it twice because it was still pulling left.
as far as the tires the right said, for whatever reason, is a bit more worn, but it is not a significant difference.
also i might add that the car only pulls left under acceleration, when coasting it tracks straight, which now i think it might have something to do with the engine mount(s).
thanks again
D_TY3
Sep 5, 2007 02:16 PM
djsire
Sep 21, 2006 09:46 AM
Woody150
Sep 19, 2005 10:34 PM
litlekikr
Feb 12, 2004 08:57 PM
GSR4sho
Oct 5, 2003 04:54 PM
