Suspension & Brakes Theory, alignment, spring rates....
Camber Help!
Old Apr 26, 2010 | 06:06 PM
Prelude man's Avatar
Default Camber Help!
I race an 85 Honda prelude on an oval track, and I need way more negative
camber on the right side
but i don't know how to get it. I have slotted the upper control arm to have
it slide more but the steering knuckle holding both ball joints that goes in
fromt of the coil and shock, well i can't move it anymore as it will hit the coil
when i turn the wheel. My only option is to bend that knuckle so it pulls the
top of the caliper in, but that is hard to do.
Is there any such thing as a lower adjustable ball joint????
Or is there any other way of getting more negative camber on the right
side???? Let me know anything is useful!
Old Apr 28, 2010 | 02:13 PM
98civdx's Avatar
Master Detailer
Default Re: Camber Help!
Getting a camber kit is the only real way i know of, i would never ever bend the knuckle.
Old Apr 28, 2010 | 02:20 PM
02 accord's Avatar
You could drill the subframe and move the lower control arm mounting point outwards.
Old Apr 28, 2010 | 02:26 PM
TunerN00b's Avatar
Especially since shifting the subframe to the side will increase negative camber on one side of the car, but decrease it (add positive camber) on the other, which is probably something a circle track car could make use of.
Old Jul 2, 2010 | 08:25 PM
okay welll thanks guys I was just looking at that the other day actually!
bake1782
May 9, 2008 08:06 AM
6doorsentra
19
Jul 10, 2007 11:11 AM
revlimitcrx
Suspension & Brakes
Nov 28, 2005 06:49 AM
..::91TEG-G2::..
May 23, 2004 01:53 PM
