Suspension & Brakes Theory, alignment, spring rates....
Brake problems
Old Nov 14, 2013 | 08:34 PM
malilaz's Avatar
Default Brake problems
1994 Accord vti-s (CD5)
I have a problem that when ever I start my car and put my foot on the brake, the brake lamp light will come on, e-brake light will appear and the abs light will pop up about 20 seconds into my trip. please help
Old Nov 21, 2013 | 09:57 PM
slowcivic2k's Avatar
Default Re: Brake problems
Fluid level in the ABS reservoir is low, and the master cylinder fluid level is low. Find the source of the leak, and inspect the brakes for wear.
Old Nov 23, 2013 | 12:28 AM
malilaz's Avatar
No leaks , resevoir is full, no problems at all with brake pads
Old Nov 23, 2013 | 12:42 AM
Short in the brake fluid level sensor, replace the cap, replace the ABS modulator assembly (defective). Are you sure the fluid level in BOTH the ABS reservoir and master cylinder reservoir are full?
95GSRBOI
Nov 14, 2012 03:55 AM
Tip14
Aug 16, 2007 03:32 AM
alfer
Jun 7, 2003 03:45 PM
Hybrid CRX
Jun 6, 2003 08:13 AM
Camelflaj
Aug 29, 2002 07:41 AM
