Suspension & Brakes Theory, alignment, spring rates....
Alignment Question!!
Old Feb 10, 2007 | 01:42 AM
The Si's Avatar
Default Delete
Modified by TheSi at 3:41 PM 3/22/2007
Old Feb 10, 2007 | 02:25 AM
The Si's Avatar
Default Re: Alignment Question!! (ThaSi)
Old Feb 10, 2007 | 07:43 AM
PIC Performance's Avatar
Yes, get an alignment. It will be necessary to zero out toe and prevent excessive tire wear.
Old Feb 10, 2007 | 02:10 PM
The Si's Avatar
Default Re: Alignment Question!! (PIC Performance)
alright alignment w/o camber kit
Old Feb 13, 2007 | 12:46 PM
The Si's Avatar
I NEED A CAMBER KIT!! the shop said they cant do it without one!! front and rear
Old Feb 13, 2007 | 12:50 PM
Tyson's Avatar
tell them you dont care about the camber and fix the toe.
Old Feb 13, 2007 | 12:51 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaSi &raquo;</TD></TR><TR><TD CLASS="quote">I NEED A CAMBER KIT!! the shop said they cant do it without one!! front and rear</TD></TR></TABLE>
Um no. The shop cannot get the car to the original alignment specifications without them, but why would you want the original alignment? Youv'e changed the spring rates, ride height, center of gravity, roll center, blah blah, etc... and now want to use the original alignment specifications?
Just tell the shop to correctly set the toe. "Correctly" isn't necessarily OEM spec, as that is a personal preference and the OEM toe spec calls for some rear toe in, and many people prefer 0 toe all around. You will have more camber than a stock car. Thats part of lowering. However, increased negative camber isn't wrong for a lowered car. Its simply not stock, but neither is the suspension.
Old Feb 13, 2007 | 01:57 PM
The Si's Avatar
Default Re: Alignment Question!! (TunerN00b)
Summary-
Left Front Right Front
Camber -2.2 -1.5
Caster 1.4 1.0
Toe -0.39 -0.49
FRONT
Cross Camber -0.7
Cross Caster 0.4
Total Toe -0.88
Set Back -0.06
Left Rear Right Rear
Camber -2.6 -2.5
Toe 0.18 0.24
REAR
Total Toe 0.41
Thrust Angel -0.03
what should i exactly do?
Old Feb 13, 2007 | 02:01 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaSi &raquo;</TD></TR><TR><TD CLASS="quote">Summary-
Camber -2.2 -1.5
Caster 1.4 1.0
Toe -0.39 -0.49
FRONT
Cross Camber -0.7
Cross Caster 0.4
Total Toe -0.88
Set Back -0.06
Camber -2.6 -2.5
Toe 0.18 0.24
REAR
Total Toe 0.41
Thrust Angel -0.03
what should i exactly do?</TD></TR></TABLE>
FIX YOUR TOE
Old Feb 13, 2007 | 04:30 PM
The Si's Avatar
Default Re: Alignment Question!! (Tyson)
thats all i need to do ? how about my camber wear on my tires
Old Feb 13, 2007 | 04:42 PM
Tyson's Avatar
its caused by your toe.
Old Feb 13, 2007 | 09:20 PM
willywong's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaSi &raquo;</TD></TR><TR><TD CLASS="quote">thats all i need to do ? how about my camber wear on my tires</TD></TR></TABLE>
camber wear is not as dramatic as wear from your toe.
Old Feb 14, 2007 | 12:35 PM
TunerN00b's Avatar
I daily drive with -4.0* front camber, -1.3* rear. So, if anyone should see "camber wear" it would be me. Now, I would expect "camber wear" to be on the inside of the tire, and I would think most people would think so as well, but that isn't where my tires have the most wear.
Since I just got a flat and have one of the tires off the car, I took some tread depth measurements. Outer shoulder 8/32", center 9/32", inner shoulder 9/32". The tire has been on the car for 1 year, and they're Toyo Proxes 4, so that seems about normal wear for my lower average annual mileage. But, why is the inner shoulder worn more than the outside shoulder? My guess, is that the slight rear toe in (factory spec for rear toe on an Integra) that I have caused it. I measured the other 3 tires as well, and they're all worn the exact same, in the same places. I also rotate monthly, if that makes a difference, when I switch to Azenis for autocross.
So, 1 year and about 9k miles, and the front camber setting has varied from -2.8* up to my current -4.0* over the year, and my tires are wearing perfectly normal. In fact, at this rate, they'll be old and hard before I burn through all the tread.
-2.2* is nothing to worry about. Just get the toe set correctly, and you'll be fine.
Old Feb 14, 2007 | 03:17 PM
The Si's Avatar
good info will doo
23LX23
Suspension & Brakes
15
Sep 6, 2010 03:31 PM
tejano_honda
Jan 19, 2008 10:40 PM
GoLowDrew
11
Dec 30, 2004 01:37 PM
94hondaLS
Sep 1, 2003 10:10 PM
96 SOHC VTEC
Jan 5, 2003 04:34 PM
