aligment setup
ok heres my setup 97 hatch with eg front 21mm sway bar 22mm asr rear setup omni power street coilovers 10k, 8k rates front carbing lower tie bar carbing front upper strut bar miracle x upper rear bfg kdw2 205/50/15. i have a life time aligment at firsestone and im looking to setup up the aligment for better handling right now it is a daily driver but i am looking to going to some autox events i currently have -1 camber on all 4 corners 0 toe im looking for a good setup to make it handle better and compliment my setup but i also dont want to wear out my tires too quickly any opinions? thanks **also what should i set my tire pressure at for daily driving**
Modified by jdmdohcek98 at 10:53 PM 8/31/2008
For daily tire pressures, start off with whatever is recommended on the sticker inside of the door. Regardless of tire size, its the best starting point for your car.
For alignment, that comes down to driver skill. I'd start off with -3*/-1.5* of camber (depending on tires), and leave the toe 0 front and back. This will improve cornering without killing the tires. Running 0 rear toe on the street is a little risky, but if you've already been doing it...
You might want to run a couple of events with your current setup, without changing a thing, in order to get a feel for how it behaves. Then start making changes.
Oh and try some punctuation next time. I had to read that post twice, slowly, just to comprehend what it said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Oh and try some punctuation next time. I had to read that post twice, slowly, just to comprehend what it said.</TD></TR></TABLE>
LOL x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">Running 0 rear toe on the street is a little risky, but if you've already been doing it...</TD></TR></TABLE>
why is that bad?
LOL x2
why is that bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Declectic »</TD></TR><TR><TD CLASS="quote">
why is that bad?</TD></TR></TABLE>
Because Honda specified a little rear toe in for safety.
Rear toe in increases high speed and braking stability, especially with the way the rear suspensions on the EG, DC, and (I think but am not positive) EK toe out under droop. Hit the brakes, weight transfers forward, rear suspension toes out on both sides...
And I agree with PatrickGSR94.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">You might want to run a couple of events with your current setup, without changing a thing, in order to get a feel for how it behaves. Then start making changes.
This is a great way to approach changes to the car.
wakaranai
17
Oct 1, 2009 10:02 PM
Steve91
33
Aug 28, 2002 07:04 PM
haha
