Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
alignment setup
Old Aug 31, 2008 | 06:41 PM
jdmdohcek98's Avatar
Default alignment setup
ok heres my setup 97 hatch with eg front 21mm sway bar 22mm asr rear setup omni power street coilovers 10k, 8k rates front carbing lower tie bar carbing front upper strut bar miracle x upper rear bfg kdw2 205/50/15. i have a life time aligment at firsestone and im looking to setup up the aligment for better handling right now it is a daily driver but i am looking to going to some autox events i currently have -1 camber on all 4 corners 0 toe im looking for a good setup to make it handle better and compliment my setup but i also dont want to wear out my tires too quickly any opinions? thanks **also what should i set my tire pressure at for daily driving**
Modified by jdmdohcek98 at 10:53 PM 8/31/2008
Old Aug 31, 2008 | 09:36 PM
OMGWTFBBQ!'s Avatar
If you want a more responsive steering feel I would set your toe the tiniest bit positive. Like .1 degrees. I set my toe to 1 degree of toe out when I drove to get new tires and it was like a whole new car. Just remember toe eats tires.
Old Aug 31, 2008 | 11:01 PM
Default Re: (OMGWTFBBQ!)
.1 toe out front or rear? also i know camber/toe eats tires but how bad would .1 eat tires compared to having -1 camber on all 4 corners? and how should i setup the camber all the corners the same? or should the front or rear be less or greater than each other? should i add more -camber or reduce?
Old Sep 1, 2008 | 05:03 AM
Lo-Buck EF's Avatar
Default Re: (jdmdohcek98)
1/16th total te out up front
youll need more camber too. but get out there and run some events, then see what youll beed.
camber does not kill tires. toe kills tires.
<----4*f, -3*r tires got killed by broken stuff giving the car random toe out
Old Sep 1, 2008 | 06:56 AM
Default Re: (Lo-Buck EF)
yea im going to run in some events i just wanted to go in there semi prepared i know with experience i will find my own setup. but -4 f -3 r is a bit extreme for my daily lol maybe -2 f -1 r? does running more negative up front help handling better than one number f&r?
thanks for the info guys
Old Sep 1, 2008 | 07:13 AM
Lo-Buck EF's Avatar
its more of a balance. you need more camber up front cause thats where all the weight and load is. the rear is along for the ride. you dont need any camber out back for autocross and minimal for track use (i have -3* for another reason)
Old Sep 1, 2008 | 11:09 AM
Jaker's Avatar
I autocrossed my EF hatch for years with 1/16" total toe out in the front and zero toe in the rear as well as 2.75 degrees negative camber in front and 1.5-1.75 degrees negative in the back. I also daily drove the car, and I certainly did not destroy tires at any rapid rate. Sure, the tires wore the inside shoulder faster than the outside, but after 15,000 miles or so of driving, there was maybe 1/16" difference in the wear.
vwtohonda
14
Apr 14, 2010 07:24 AM
wakaranai
17
Oct 1, 2009 10:02 PM
jdmdohcek98
Suspension & Brakes
Sep 11, 2008 07:02 AM
Chim Chim
Suspension & Brakes
Apr 23, 2007 10:25 PM
Black R
May 24, 2003 03:49 PM
