Adding camber kit, will it change toe?
Im planning on installing my front and rear camber kits tomorrow, but was wondering if the TOE will change if i install camber kits. I just had my toe adjusted to 0 degrees on all the corners and didnt want to get another alignment if toe won't change if i add camber kits.
you should just buy the lifetime alignment at firestone. not only should you align your car after this, you should align it once a year. i actually do mine when i switch from summer to winter tires and again winter to summer.
crazy part is the setting change even in such a short period. the main reason i do this is front toe out. i run near zero on snow tires and always toe out summer tires. my snow tires are .01 out each side in the front and .05 in each side in the back. on summer tires the fronts are out around .04 each side
todds94teg
Sep 5, 2003 06:14 AM
