Tein Flex, SSR, Volk, B16 Quaife, Fluidyne, Sparco, Autopower, Hondata
I'm moving to L.A. October 15th so I figured I would post this stuff up. Thanks for looking and feel free to pm me with any questions/offers. I'll be adding more stuff as I pack it up this week.
1. Tein Type Flex with JDM ITR rear lca's. Coilovers and LCA's were both bought brand new and have approximately 2000 miles on them. SOLD!!!!!!
2. B16 hydro Transmission with Quaife LSD. All new bearings approximately 30 miles ago. No Grinds, Shifts like butter with absolutely no issues. Small hairline crack by snap ring on casing w/jb weld. Does not leak. New OEM diff/axle seals and detent plungers and *****/springs. $1400
3. ACT 6 puck unsprung disc with Xtreme pressure plate and Clutch Masters 7.5 lb flywheel for hydro b-series. Used with 3500 miles. $300
4. Autopower 4-point rollbar for 92-95 civic hatchback. All hardware included. SOLD!!!!!!
5. Sparco Sprint race seats. Black in color. Mint condition. Comes with rails and sliders for 92-95 civic or 94+ tegs. SOLD!!!!!!
6. Fluidyne half size radiator with Spal fan. SOLD!!!!
7. Optima battery (Brand new yellow top, just replaced) with custom mount and bracket for rear of vehicle. Comes with Phoenix Gold terminals, 0 guage wiring from rear of vehicle to front w/loom, and Phoenix Gold disconnect cutoff switch. $275
8. MSD 6al with Blaster Coil and custom mounting tray and OBD1 LS distributor and coil wire. $425
9. STR Intake Mani for LS motors with Hondata heat shield gasket and OE throttle body. $350
10. Inline Pro Polished Fuel Rail with Precision 1000cc injectors. SOLD!!!
11. Hondata s200b w/ls ecu. Already tuned with 1000cc injectors for my setup. SOLD!!!!
12. 3" stainless exhaust with 2 3" resonators. Very nice. SOLD!!!!!!
13. Totem Traction Bars. Clear H22 oil pans in eg's/tegs. For 92+civic and 94+teg. SOLD!!!!
14. Complete Turbo setup. Made 340whp/270wtq + some on a bone stock LS motor. XS Engineering TO4X turbo, Custom 2.5" charge pipes, HKS Type R BOV w/filter, Tial 35mm wastegate, 3" custom downpipe, Maxrev stainless mani, Stainless dumptube, Greddy type 24 Large FMIC, -10 Stainless braided return line with earl's fittings, -4 stainless feed line with oil feed tee for back of block, Turbo XS manual boost controller, GM 3bar map sensor with pigtail, Golden Eagle Vacuum Block, LS oil pan with -10 Earls fitting for drain, and ALL couplers, vacuum lines, t-bolt clamps, and everything needed. All you would need is a fuel setup and modifying the upper charge pipe depending on your intake mani. $2650
15. 92 Civic 4-door rolling shell. Integra front and rear brakes. Fronts have ARP extended studs with new wheel bearings and powerslot cross drilled/slotted rotors. Chassis is wire tucked. Interior has integra dash with oem cd player, teg center console, Momo Monte Carlo steering wheel and Momo hub, Greddy shift ****, Alpine front door speakers, but is stripped other than that. Has Sparco hood pins and amber corners. Also has Walbro 255hp fuel pump. Body is in great shape with normal dings scratches. Has OEM eg9 ferio front lip. Original paint, CLEAN TITLE, no rust. SOLD !!!!!!!
16. Enkei RPF1's. 15x7 +35mm w/falken 512's. Flawless condition! I bought these brand new and pretty much sat on the car in the garage. SOLD!!!!!!!!
17. Volk GRN's. 15x7 +35mm. ONLY A PAIR! with BFG 225/50/15 Drag Radial. SOLD!!!!!
18. Volk TE37's 15x7 +43. 4x114.3 and bronze in color. New stickers. Original valve stems and caps. All wheels in great condition with no bends. One wheel has slight rash as shown circled in pictures from a slight rub. Some clear coat missing on the faces. SOLD !!!!!!!
19. SSR Type C's 15x7 +43. Has 95% new Falken Ziex 512's 205-50-15's. Wheels are White in color and 4x100. Very rare and hard to find in this size/color. One wheel has a super slight bend (barely noticeable and does not affect balance) and a couple have a few scratches/rash on the outer lips. ORiginal Valve Stems and caps and Original Stickers! These could definitely use a good cleaning and I will get pics up as soon as I can get my car out of the garage.Price -- $1400 obo with tires or $1250 obo without.
Thanks for looking and here are some pics of the car and then the parts.
Brandon
Brandon
