FS: Built High compression LS
I'm selling my Built LS motor. Got another motor lined up and I need the money. It burns a bit of oil thanks to valve stem seals. I bought the head from a member on here that said they were replaced, but apparently they werent...or maybe they just got old from not being used for a while. I dunno, but it burns some oil. That's the only place I can think of that it would do it from. All the work done to the head was by the person I purchased it from. Machine work to the block was done at a machine shop in downtown greenville
Specs on the motor:
Head:
Ported and polished
Crower dual valve springs
Crower titanium retainers
Crower 62404 cams
3 angle valve job
AEM Fuel Rail
RC 310cc injectors that were sent to RC for cleaning/calibrating when I assembled this motor.
Block:
Bored to 82mm
JE 11.5:1 forged pistons and rings
Eagle H beam rods
ARP rod bolts
ACL main and rod bearings
micropolished and balanced crank/rotating assembly
ARP head studs
GSR water pump
ITR oil pump
GSR timing belt
OEM headgasket
Golden Eagle block guard
ARP flywheel bolts and pressure plate bolts
LSD Motorsports 8lb flywheel
BBK 62mm throttle body
Blox intake manifold
I will also throw in a hondata IM gasket
I made 173whp and 136ft lbs with a 2.5" intake, 2.25" exhaust/OE muffler and a busted *** DC header. this motor still has tons of potential!!
<FONT SIZE="15">$2500!!
</FONT>
PICKUP ONLY!
Modified by B16CRXT at 10:46 PM 11/13/2008
Specs on the motor:
Head:
Ported and polished
Crower 62404 cams
3 angle valve job
AEM Fuel Rail
Block:
Bored to 82mm
Eagle H beam rods
ARP rod bolts
ARP head studs
GSR water pump
ITR oil pump
GSR timing belt
OEM headgasket
</FONT> PICKUP ONLY!
I appreciate it Patrick. Where the hell have you been man? I haven't heard about or seen you in forever. Also, I'd rather sell it all together and not part it out. I don't want leftovers.
and for the parting out...i would've bought the block if he bought the head lol
B18 CYA
Feb 4, 2007 10:37 AM
