trany sound
it makes the noise when i am in 1st-3rd what is it? is it my trany going? is it going to go out on me just riden down the road? do i need to change my trany oil? used search to look it up and found things about (trany for sale no grind) but that is it
here you go bud i have teh same problem i thought it was throwout bearing but it wasnt now i think its input shaft bearing but this guy seems to prove me wrong also... but here is the likn https://honda-tech.com/zerothread?id=956991
my old D16A6 tranny began to make a horrible throbbing metal noise when in 1st-3rd gear.
never got it fixed because i swapped in a DOHC soon after. my friend pulled the tranny apart and saw that a couple of the bearings were bad. no details on exactly which ones, sorry.
anyways, bump to help these guys out.
i drained my trany today and had metal in it not much but some also the oil that came out smells funky not like oil starting off in first it will not make a sound until i hit the gas or i get above 3000 rpm (any more info)
it is ether a SI or ZC. it's kind of like a grinding noise but it dose it when i am in gear not when the clutch is engaged. some time when i go into 3rd hard it will grind but that's the only gear. so i don't think that it is the syncros could it be a bearing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importslife »</TD></TR><TR><TD CLASS="quote">it is ether a SI or ZC. it's kind of like a grinding noise but it dose it when i am in gear not when the clutch is engaged. some time when i go into 3rd hard it will grind but that's the only gear. so i don't think that it is the syncros could it be a bearing?</TD></TR></TABLE>
Sounds like an input shaft bearing (Same problem on one of my SI's).
Easy to fix, just a pain in the *** to get to the bearing.
Matt (SG)
Jun 5, 2008 05:06 PM
Manolo
Aug 27, 2007 03:14 PM
NipponRacing
13
Sep 5, 2003 06:42 AM
NipponRacing
May 3, 2003 03:09 AM
