fans which is better push or pull
Old Sep 22, 2004 | 05:19 PM
gato5254's Avatar
Default fans which is better push or pull
hello my questions is about the rad fans because i have a b18c-r in my 96 civic and i put in a 3 row rad from an integra that goes across the hole front. right now i only using one fan because i haven't bought the thin fans yet but looking into that i saw that there are two types of fans push and pull. the push mount in front and the pull behind. i think i have enough room to mount them in front but does it make a differnce. Also has some one done this that has any tips. the motor doesn't over heat and the summer is over but i would rather be safe than sorry. Thanks for any help
Diego
Old Sep 22, 2004 | 05:21 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: fans which is better push or pull (gato5254)
A puller fan is more efficient than a pusher fan. Pusher fans are generally only used in applications where there's no room for a puller fan. A fan mounted in front of a rad will block some airflow.
hondapimp125
Jun 2, 2010 11:26 AM
rjay8604
18
Jun 26, 2005 12:44 AM
InLimbo87
Jul 21, 2004 07:22 AM
95gsr
May 29, 2002 03:32 PM
