JUN cams for a Turbo Aplication
Old Dec 11, 2001 | 09:07 AM
DannyITR's Avatar
Default JUN cams for a Turbo Aplication
In a few years, I plan to build a civic hb race car. My setup will be a 96 hatch with a Greddy or Drag turbocharged B18C. My question is that after running the turbo on a stock motor for a while I will re-inforce my bottom end with better internals. Ususally a JUN setup involves high compression but for a turbo setup, I would want lower compression. What is the compression determining part in an all motor engine? Can I have the smooth JUN idle if I have a turbo setup. My top priority is a smooth idle and good driveability.
Old Dec 11, 2001 | 09:26 AM
naturalvx's Avatar
Default Re: JUN cams for a Turbo Aplication (DannyITR)
JUN does not offer a "turbo specific" cam yet. You might be able to use 1s or 2s but you have to be careful to not have to much overlap for FI applications. If you aren't planning to do this for a few years I wouldn't bother worrying. THe import arena has changed in the past 2 years and who knows what will be available in another 2 years. I believe JUN will have specific application cams available by then but you never know.
Old Dec 11, 2001 | 09:34 AM
BowSeR's Avatar
New User
Default Re: JUN cams for a Turbo Aplication (naturalvx)
JUN 1's would be more for turbo. but i wouldnt go with anything more than ITR cams
Old Dec 11, 2001 | 09:52 AM
DannyITR's Avatar
Default Re: JUN cams for a Turbo Aplication (BowSeR)
Yeah, I was thinking that in a few years, there will probably be turbo specific cams and other parts required to strengthen the bottom end.
My other question was what exactly raises the compression? Anything that shrinks the volume inside the compression chamger will wont it? Do I need to alter the compression alot for the turbo setup?
Old Dec 11, 2001 | 11:29 AM
Big Phat R's Avatar
Your choice of piston dome design (usually measured in cubic centimeters) will determine compression (along with bore and stroke). Most turbo applications use a non-domed (i.e. flat) piston head design in a compression ratio of about 9:1
Old Dec 11, 2001 | 04:14 PM
DannyITR's Avatar
Default Re: JUN cams for a Turbo Aplication (Big Phat R)
I've often heard people favour crower parts for turbo motors. I thought crower were re-grinds and were of lesser quality.
10secondhatch
Jan 8, 2004 04:50 PM
Daysleeper
Oct 22, 2003 03:49 AM
zer0zer0 TypeR
Oct 25, 2002 07:25 AM
TypeR 599
Sep 16, 2002 06:23 PM
617arg
Jul 17, 2001 05:56 AM
