Toda B cam problem!!!!
Old Sep 22, 2004 | 05:02 PM
Edw-R's Avatar
Default Toda B cam problem!!!!
I just installed Toda B cam. My mechanic adjust intake +4, exhaust +1. Does anyone know which combination is the best??? I got 107 kw on the wheel. The best 0-400m is 14.19s. Hoppe you can give me some opinions!! Thanks a lot!!
Old Sep 22, 2004 | 06:03 PM
Big Phat R's Avatar
Default Re: Toda B cam problem!!!! (Edw-R)
Cam settings vary from motor to motor.
You need to tune the cam settings on a chassis dyno with a wideband 02 sensor in the tailpipe.
Old Sep 22, 2004 | 06:38 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edw-R &raquo;</TD></TR><TR><TD CLASS="quote">I just installed Toda B cam. My mechanic adjust intake +4, exhaust +1. Does anyone know which combination is the best??? I got 107 kw on the wheel. The best 0-400m is 14.19s. Hoppe you can give me some opinions!! Thanks a lot!!</TD></TR></TABLE>
That's quite a bit, be very careful, or leave it at stock until you can get some dyno time.
Old Sep 22, 2004 | 07:44 PM
Bbasso's Avatar
Default Re: Toda B cam problem!!!! (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">
That's quite a bit, be very careful, or leave it at stock until you can get some dyno time. </TD></TR></TABLE>
I was thinking the same.
Old Sep 23, 2004 | 08:22 AM
Edw-R's Avatar
The mechanic tried follow the Toda b cam info. But it ran on dyno 82kw. Andthen, he tried intake +4, exhaust +1. He told me that is the best power(107kw). I used toda a cam before. Same dyno mechine, i got 111kw. I can't believe why i lose power. How can i do??
Old Sep 23, 2004 | 08:41 AM
Splat's Avatar
Collector-o-Guns and Drinker
Other mods?
Old Sep 23, 2004 | 08:50 AM
slammed_93_hatch's Avatar
its REALLY hard to under stand what your saying, but dyno's have been know to give different number befor.
was it hotter? more humid?
tons of things effect dyno's
Old Sep 23, 2004 | 09:14 AM
Big Phat R's Avatar
Please give us a listing of all your modifications.
Are you running stock injectors? Have you adjusted fuel pressure at all?
I got 156kW out of my B's with high compression pistons, Hondata and Hytech exhaust.
107kW = 143 whp - something is not right
Old Sep 23, 2004 | 07:00 PM
Edw-R's Avatar
Default Re: Toda B cam problem!!!! (Big Phat R)
Thank you for your help!! Modification as below:
Toda B cam
Toda cam gear
Toda valve spring
Mugen head gaskit
Port and polish head and throttle body
5 zigen full exhaust system
Apexi power fc
HKS twin power
Hotwire cable
idr spark plug
ARC intake system
How can i do?? I am very confuse!!!!!!!!!!!!!
totsie7944
Aug 30, 2005 05:54 PM
Edw-R
Sep 11, 2004 11:19 PM
JerseySiPOS
12
Sep 10, 2004 11:31 AM
Jim80y
Aug 5, 2004 10:04 AM
Edward
Mar 28, 2004 04:18 PM
