alright.. o2 sensor CEL43 question for you guys
Old Sep 22, 2004 | 04:35 PM
vuthe32's Avatar
Default alright.. o2 sensor CEL43 question for you guys
i got a CEL 43 - Fuel Supply
my friend said could be an bad o2. changed that out (with a bosch 4 wire). still getting the CEL 43. any ideas?
this is how i wired up the o2:
stock Bosch
blk------------blk
blk------------blk
wht-----------blue
grn-----------wht
any ideas if i wired it right or if there is some sort of "master reset?"
thanks
Old Sep 22, 2004 | 04:40 PM
britishlude's Avatar
Default Re: alright.. o2 sensor CEL43 question for you guys (vuthe32)
Not sure about the wiring but did you reset the ECU after ? remove the clock /radio fuse in engine bay or take off your Negative lead from battery for 10 mins and it should clear your old trouble codes if fixed, make sure you have your radio code before doing this. But I can't see why a faulty o2 sensor would give you a code 43 in the first place, as it's for a defective fuel supply ?
Old Sep 22, 2004 | 07:21 PM
vuthe32's Avatar
Default Re: alright.. o2 sensor CEL43 question for you guys (britishlude)
hey thanks.. i just did what you said.. and the car isnt throwing any more codes. when i check to see the code.. the engine light would be on the whole time. not blinking... this is with the jump wires in that harness.
however my 4ws light blinked.. i think it's a code 53? or 62? i dunno...
thanks for the help
Old Sep 23, 2004 | 05:44 PM
vuthe32's Avatar
welp... i drove to school no engine light. it was 13 miles from my house. then coming back from school to home... anotehr 13 miles no light. i even punched on and off and kept it steady for like 5 minutes at 80mph. nothing yet. i just jumped it to see if there would be a code. nope. no code.. only code i got was for my stupid 4WS light. i got a code 62 i think. any idea on what it is?
so far no light... which is good i guess, no change in performance of the car, too early for gas mileage.
Old Sep 23, 2004 | 06:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vuthe32 &raquo;</TD></TR><TR><TD CLASS="quote">welp... i drove to school no engine light. it was 13 miles from my house. then coming back from school to home... anotehr 13 miles no light. i even punched on and off and kept it steady for like 5 minutes at 80mph. nothing yet. i just jumped it to see if there would be a code. nope. no code.. only code i got was for my stupid 4WS light. i got a code 62 i think. any idea on what it is?
so far no light... which is good i guess, no change in performance of the car, too early for gas mileage.</TD></TR></TABLE>
Have a look at this previous thread that starts off with a code 62 on the 4ws system, read it thoroughly theres a write up with pic's and that fix worked for a few guys who were having probs with the 4ws electronic control unit.
https://honda-tech.com/zeropost?cmd=tshow&id=886363
And here's the fix with pictures to make life easier for you.
http://sephro.x-industries.com/4ws/
Spug
May 26, 2012 12:15 AM
boostinh22
Nov 29, 2005 11:15 AM
Qwikrex
Jun 22, 2002 12:52 PM
RJL
Nov 25, 2001 04:36 PM
