Wheel Bearings
Old Sep 22, 2004 | 02:48 PM
monsterb18b's Avatar
Default Wheel Bearings
Does anyone have a "how to fix" wheel bearings instructions?
Old Sep 22, 2004 | 02:56 PM
SloCivicHMM's Avatar
Default Re: Wheel Bearings (monsterb18b)
yeah get new ones!!!
Old Sep 22, 2004 | 03:00 PM
Deemeetree's Avatar
Electrician
Default Re: Wheel Bearings (SloCivicHMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM &raquo;</TD></TR><TR><TD CLASS="quote">yeah get new ones!!!</TD></TR></TABLE>
LOL. ******* butt monkey.
But yeah, you need to get new ones. It's a bit of a pain in the *** to replace since you need access to a press to get the old ones out and the new ones in. If you have access to a press and an impact wrench, it's a very easy job.
Old Sep 22, 2004 | 03:03 PM
brentmc79's Avatar
You typically have to replace the entire hub when the bearing goes out. Although, if you have a press like Dimi said, then you may not need to. Actually, now that I'm thinking about it, I don't think you can buy just the bearing. Anyway, here's how to change the bearing/hub assembly:
-Take off your wheel
-Remove your drum/caliper/rotor
-Use a screwdriver to 'un-dent' the bearing nut
-Using a 32mm socket (I believe that's the right size), remove the bearing nut
-Remove old bearing/hub and install new one
-Reassemble everything
Old Sep 22, 2004 | 03:04 PM
RevenantAE's Avatar
Do you mean how to replace them? Typically you can't fix a bad wheel bearing. You CAN repack them with grease, but that's really a maintenance issue. If the bearing is actuall bad, it won't do anything for you.
Old Sep 22, 2004 | 03:35 PM
Deemeetree's Avatar
Electrician
Default Re: Wheel Bearings (brentmc79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brentmc79 &raquo;</TD></TR><TR><TD CLASS="quote">You typically have to replace the entire hub when the bearing goes out. Although, if you have a press like Dimi said, then you may not need to. Actually, now that I'm thinking about it, I don't think you can buy just the bearing. </TD></TR></TABLE>
Yes you can:
44300-S04-004 BEARING ASSY., FR. HUB (KOYO SEIKO) $56.66
This is for a 1995 LX/DX anyway.
EDIT:
I read another thread you created. This is for a 1995 EX:
44300-S04-A02 BEARING ASSY., FR. HUB (KOYO SEIKO) $49.80
Old Sep 22, 2004 | 04:30 PM
RCautoworks's Avatar
Default Re: Wheel Bearings (Dimi)
A slide hammer actually works also.
Old Sep 22, 2004 | 04:34 PM
WyteNyteGSR's Avatar
yep
Old Sep 22, 2004 | 04:51 PM
TallAssFilipino's Avatar
Default Re: Wheel Bearings (WyteNyteGSR)
You can buy a bearing alone. I had a right-front bearing go bad. I took off calipers, disk/rotor, then hub. I took the hub and the hub/wheel bearing (that I bought alone) to a shop where they had to machine press the bearing out. They also put the new one in.
A slide hammer (when used with a hub remover/puller) only lets you remove/pull the hub from the knuckle (if front) or trailing arm (if rear).
(images borrowed from user: 743power)
Old Sep 22, 2004 | 05:45 PM
RevenantAE's Avatar
Default Re: Wheel Bearings (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">A slide hammer actually works also.</TD></TR></TABLE>Don't you need to have the race pressed out? Not familiar with the hub in question, but on most hubs I am familiar with, proper application of force will only get the bearing apart, it won't get the inner race out.
RacerTim
Sep 10, 2010 05:44 PM
EX-T
15
Sep 12, 2008 06:53 AM
petergriffen
Aug 11, 2006 08:44 PM
buzlink
Jul 18, 2002 06:44 PM
pcorad
Nov 7, 2001 08:41 AM
