subframe damage
Old Sep 22, 2004 | 11:47 AM
EMphaticONE's Avatar
Default subframe damage
does $450 sound like a fair price to have my front passenger side subframe straightened out? its on a 00 Si by the way. TIA
Old Sep 22, 2004 | 12:18 PM
Default Re: subframe damage (pearlblueb16)
anyone?
Old Sep 22, 2004 | 12:21 PM
murtnabila's Avatar
its seems like a fair price
Old Sep 22, 2004 | 12:45 PM
hayabusa160's Avatar
Default Re: subframe damage (murtnabila)
thats not bad
Old Sep 22, 2004 | 01:19 PM
_BEN_'s Avatar
Default Re: subframe damage (hayabusa160)
Are you referring to item 1?
If you are
Its only 140.49 and it can probably be removed and replaced with normal hand tools. I know on the eg/dc chassis the sub frame bolts on.
Old Sep 22, 2004 | 01:51 PM
capbyrd's Avatar
i think he may be talking about the actual frame. if so, then that sounds like a pretty decent price.
Old Sep 22, 2004 | 02:53 PM
]{iwi's Avatar
450 sounds good check other shops around as well but dont go for the cheapest job it may not be ur best bet
Old Sep 22, 2004 | 03:45 PM
dantastic's Avatar
i slid into a curb and had bent my rear subframe, where the LCA attaches to the body. i had it pulled out 1/2" for $100 on a frame jig/puller
Old Sep 22, 2004 | 05:35 PM
murtnabila's Avatar
Default Re: subframe damage (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">Are you referring to item 1?
If you are
Its only 140.49 and it can probably be removed and replaced with normal hand tools. I know on the eg/dc chassis the sub frame bolts on. </TD></TR></TABLE>
If it's item 1 I can sell it for 50+shipping
Old Sep 23, 2004 | 11:53 AM
it is item #1, why would i be charged so much to have it bent back if it can be replaced for $100 (or even $50 as mentioned)? Is there much difference between replacing it and having it bent back?
Old Sep 23, 2004 | 11:54 AM
I was told it's the subframe by the way, not the actual frame.
Old Sep 23, 2004 | 11:57 AM
Ajax's Avatar
Well, thats because it will a LOT of labor to buy a subframe and put it on. I'd still rather have a new subframe then a bent one pulled back out though.
Old Sep 23, 2004 | 11:59 AM
Default Re: subframe damage (Ajax)
what price difference am i looking at between having it bent back and having a new one put on? The reason its bent is because i hit a curb pretty hard, so maybe the bend isnt that significant?
Old Sep 23, 2004 | 12:30 PM
TallAssFilipino's Avatar
It's just like when I had to have my door replaced. They were charging me more to remove the door skin from the door skeleton and to replace it with a new door skin when buying a whole new door was much cheaper. Just replace it. Nothing beats new. Almost nothing, in many cases, at least.
Old Sep 23, 2004 | 12:33 PM
murtnabila's Avatar
I quoted 50+shipping cause I'm taking it off my car I'm parting out. It's 140 new. I would rather replace it over getting old one straightened out. They're charging labor by the hour most likely and probably how long it's gonna take. At first I thought you were talking about the frame not the subframe. Replacing it is pretty much taking bolts off and the replacing them back with the new subframe.
Old Sep 23, 2004 | 12:37 PM
i just talked to the mechanic (hes a honda tuner as well), and he said its too labor intensive to replace. Isnt it just some sort of machine that straightens out the subframe? its an 00 Si.
Old Sep 23, 2004 | 12:40 PM
murtnabila's Avatar
don't know about the 00 si. But the eg are pretty simple.
Old Sep 23, 2004 | 12:57 PM
Ajax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlblueb16 &raquo;</TD></TR><TR><TD CLASS="quote">i just talked to the mechanic (hes a honda tuner as well), and he said its too labor intensive to replace. Isnt it just some sort of machine that straightens out the subframe? its an 00 Si.</TD></TR></TABLE>
Get a new mechanic.
Old Sep 23, 2004 | 01:13 PM
the mechanic was talking in terms of price per labor hour. he was saying that its more cost effective to have it bent back, as opposed to buying a new one and putting it on. i obviously want to have a new one installed, but if the difference in price is too much i guess i dont have much of a choice.
Old Sep 23, 2004 | 02:13 PM
ok. so im confused now. I talked to a guy at the honda dealer and he quopted me the whole front engine subframe for $542.52, but i talked to 2 other honda dealerships and they both said around $190. the guy who quoted me $542 is a honda head, so maybe the dudes who quoted me $190 weren't quoting the right price?
Old Sep 23, 2004 | 02:15 PM
slammed_93_hatch's Avatar
ok its NOT a easy thing to just throw the sub frame in there, and it doesn't just bolt in it welds in, and your WHOLE rear suspension ties into that ****, id pay that much to insure it was done correctly
Old Sep 23, 2004 | 02:22 PM
Default Re: subframe damage (slammed_93_hatch)
he was just quoting a price for the part alone, not the labor.
Old Sep 23, 2004 | 03:14 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">ok its NOT a easy thing to just throw the sub frame in there, and it doesn't just bolt in it welds in, and your WHOLE rear suspension ties into that ****, id pay that much to insure it was done correctly</TD></TR></TABLE>
i think they're talking about the front subframe. afaik, it bolts in
Old Sep 23, 2004 | 03:17 PM
Default Re: subframe damage (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
i think they're talking about the front subframe. afaik, it bolts in</TD></TR></TABLE>
oooo well
Old Sep 23, 2004 | 04:16 PM
94EGhatch's Avatar
DIY
