Timing belt help
I guess I am in need of some serious help. I dont trust myself to do my timing belt on my 4th Gen JDM H22. So I guess I could use any recomendations for mechanics in Northern VA or in Southwestern VA. I just need to figure out a way to get this work done sometime in the near future.
Thanks,
Ryan
Thanks,
Ryan
Alright so I found a place to do the work. My question is are the USDM Timing Belts and water pump parts the same? If not where can I get the JDM parts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSloLude »</TD></TR><TR><TD CLASS="quote">Alright so I found a place to do the work. My question is are the USDM Timing Belts and water pump parts the same? If not where can I get the JDM parts?</TD></TR></TABLE>
they're the same so just go to honda
Ok cool, I went online to http://www.prostreetonline.com...7-hnd/
Do I need all these parts for this??
Thanks,
Ryan
Thanks,
Ryan
Yes, that kit will work out fine
I would change the main seal while i'm in there. Also the balancer shaft seal is known to bust, so get the retainer for that. Your cam seals are prolly busted by now, so tack that on. Those are the important ones on that side of the block...
drdanny18
Jul 19, 2007 03:56 PM
Calean007
Nov 27, 2004 05:13 AM
