97+ Rear Rotors
Old Sep 22, 2004 | 08:46 AM
nubs's Avatar
Default 97+ Rear Rotors
I drive a 99 base lude and was wondering if I could put the same rotors in the front on the back. Cause the back rotors are smaller. I think I can get the hook upo on some rotors but only on the fronts thats why I was wondering if I just buy 4 front could I put them on the back as well. Thanks
Old Sep 22, 2004 | 08:59 AM
Wiseguy619's Avatar
Default Re: 97+ Rear Rotors (nubs)
i don't think so
Old Sep 22, 2004 | 09:31 AM
nubs's Avatar
Anyone know for sure?
Old Sep 22, 2004 | 10:11 AM
eMpAtHy's Avatar
wouldnt you need new calipers and pads if it was possible?
Old Sep 22, 2004 | 12:14 PM
99_SH's Avatar
You could do it. But you will need new calipers, pads, rotors, and caliper bracket. I believe the caliper bracket mounting holes are spaced the same front&rear.
But when you do this, you will loose your parking brake. But you knew that already, right?
Old Sep 22, 2004 | 02:12 PM
britishlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nubs &raquo;</TD></TR><TR><TD CLASS="quote">I drive a 99 base lude and was wondering if I could put the same rotors in the front on the back. Cause the back rotors are smaller. I think I can get the hook upo on some rotors but only on the fronts thats why I was wondering if I just buy 4 front could I put them on the back as well. Thanks</TD></TR></TABLE>
That's a definite NO the front rotors are a bigger diameter than rear also the front are double walled with a ventilaton cavity in the middle, so are a lot thicker as well. The stock rear caliper will not accept the diameter or the thickness, you will have to get a pair of rotors specifically for the rear.
Old May 9, 2006 | 05:06 PM
larrymotormon's Avatar
I've noticed a lot of 'Ludes just go with slotted for the rear. Looks cool. Is there any other reason for going just slots back there?
Azxster
14
Oct 11, 2007 10:07 PM
..::91TEG-G2::..
Nov 24, 2005 02:12 PM
AznBlueBoy
Jun 18, 2005 10:03 AM
ComCool
Feb 24, 2005 07:34 AM
chad
Jul 11, 2003 08:54 PM
