going wingless but keeping wing?
Old Sep 22, 2004 | 12:56 AM
Dc2 Powered's Avatar
Default going wingless but keeping wing?
hey i was wondering if i went wingless but sometime felt like sticking the spoiler back on would i need to add new adhesive or would it bolt down stong and sturdy
Old Sep 22, 2004 | 01:26 AM
nicklk's Avatar
Wow......you need to change your avatar to "NOT" the sharpest knife in the drawer......its either or......
Old Sep 22, 2004 | 01:54 AM
what the **** are you talking about? and thats not my avatar thats my title and only mods can change that, if u dont help, dont post, *******.
i wanted to know because i want to go wingless but i like the itr spoiler so i might want to put it back on and mayve take it off agian so i wanted to know should u put new adhesive and if u dont would it move around? damage anything? break off etc?
Old Sep 22, 2004 | 03:33 AM
TEAMNYC's Avatar
Default Re: going wingless but keeping wing? (Dc2 Powered)
stay wingless
Old Sep 22, 2004 | 05:46 AM
Kendall's Avatar
I never had a problem frequently removing and replacing my ITR spoiler. The adhesive eventually dried and I cleaned it off, but the bolts held it on quite well.
Old Sep 22, 2004 | 06:13 AM
dFreezy's Avatar
Default Re: (Kendall)
yeah, my brother would take his itr wing off all the time, never had problems with putting it back on, without using adhesive
Old Sep 22, 2004 | 07:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I was not aware any adhesive was used. When I took mine off I found what seemed to be the remnants of a foam pad or something used to cushion the wing so it wouldn't be in direct contact w/ the body, but it wasn't adhesive.
Old Sep 22, 2004 | 07:29 AM
The-LS's Avatar
Default Re: going wingless but keeping wing? (PatrickGSR94)
I think the foam is just to create a water tight seal for the mounting bolts and holes. Its not holding the wing down at all, I'm pretty sure the 4 bolts can do that alone.
Old Sep 22, 2004 | 07:39 AM
well i am not sure my car is a gsr butc ame with the ITR wing. and i've seen post where people have told other people to use "fishing line" or somthing like floss to cut through the adhesive so i just though it had some.
Old Sep 22, 2004 | 07:44 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: (Dc2 Powered)
Yeah, just like PatrickGSR94 said, the wings I have had experience with haven't had any adhesive.....just some foam thing to prevent scratching between the two surfaces.
Perhaps if you had an aftermarket wing (or not stock, as you said by your ITR one), the person might have used adhesive.
In any case, you don't have to worry about removal and installation. Just use the bolts and a piece of a similar foam and you'll be fine.
Old Sep 22, 2004 | 07:52 AM
i have an ITR hatch on my car. there is a vin and it checked out to be 2000 Type R hatch
so it shouldnt have adhesive? hmm.. interesting
Old Sep 22, 2004 | 08:47 AM
Community Builder
there is no reason to seal any water out on a Type R hatch because the bolt holes only go through to the drip rails outside of the weather stripping.
Old Sep 22, 2004 | 10:50 AM
SuzukaBlueAP2's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">there is no reason to seal any water out on a Type R hatch because the bolt holes only go through to the drip rails outside of the weather stripping.</TD></TR></TABLE>
Old Sep 22, 2004 | 10:54 AM
..::91TEG-G2::..'s Avatar
only way i can think of putting on and takin off a wing is to get the metal ones with the metal brakets.. you can just unbolt the wing from the braket, or put it back on when you think it would help
Old Sep 22, 2004 | 11:04 AM
Community Builder
Default Re: going wingless but keeping wing? (..::91TEG-G2::..)
you mean like those ghey aluminum wings?
oh man if I saw a car driving around with just those brackets bolted to the trunk, I would point and bust out laughing.
Old Sep 22, 2004 | 11:32 AM
nicklk's Avatar
I am not being an *******.......Use some velcro, that way when you want it, you can put it on....when you dont, take it off....
Seriously....its one or the other, If you go wingless (which seems to be the craze now) you will have holes left, which looks tacky, if you have a wing already (seeings how you said you had an ITR hatch) stay with the wing.
Renegade
Aug 17, 2006 08:52 PM
oilguzzler
Jan 22, 2006 03:26 PM
sickofitall1113
May 11, 2005 10:26 AM
TsunamiZC
Jul 8, 2002 05:01 PM
