ALMOST DONE WITH CAR ISNTALL BUT NEED HELP
Hi,
Installing a compustar into a 93 civic ex.
Ok, ive got everything down to 5 wires.
From my old clifford i have the unlock / lock wires comming from two locations, and when i took apart my alarm i forgot how they wired it.
So right now i have everything wired
in my car from the old alarm there are 2 places were the door lock /unloack wires come out, once by the door, and another time under the dash.
Do i relay those wires?
or on my alarm i have unlock?
I also have another wire called door trigger (-) from the old alarm.
Heres what Im not sure which goes to which or if i even use these but these are the connectiosn that relate to my new alarm
(this info is striaght from guide)
COnnector #3
Pin #4 Ciolet/Black Trigger input (trunk pin for trunk if opened alarm will go off)
Pin #5 Red/White (-) Trigger input for the door. You would connect this to the trigger that shows (-) when the door is opened.
Pin #6 Red THis wire is the (+) input for the door trigger. You would connect this to the trigger that shows (+) when door is open
Then theres COnnecter #4
Pin#4 Blue - This wire is (+) lock output that doubles as a (-) unlock output
pin #5 Blue/Black - This wire is the (-) lock ouput that does as a (+) unlock output
NOW, PLEASE ANY HELP WOULD BE NICE...WHAT GOES WERE?
COnnector #3
First off. you do not need to relay the door lock wires ...
POWER LOCK is green/white and POWER UNLOCK is green/red these wires can be found In the Drivers door.. right above the Speaker.. YOu will see a small Square box.
For the Existing Door trigger wire from you Clifford alarm, Connect that to Pin #5 Red/White (-) Trigger
Pin #6 Red YOu will not use, because honda are Negative triggers
now Pin #4 Violet/Black Trigger input-- connect this to grn/blk 2 silver dots on the wire... and you can find this right abloce the fuse box in a blue connector
Pin#4 Blue -hook this up to green/red of the drivers door lock module
pin #5 Blue/Black -hook this up to green/white of the drivers door Door lock module
I hope this help..
if you need any more help.. feel free to email me..
I hope this help..
ussop
Audio / Security / Video
Mar 13, 2015 11:36 PM
Kavehman
Oct 24, 2006 10:42 AM
