'90 Civic PGM carburetor
Old Dec 11, 2001 | 02:50 AM
pzoltan67's Avatar
Default '90 Civic PGM carburetor
Hello Guys,
I'm new on this list.
I living in Hungary and I bought a '90 Civic with PGM carburetor
(D13B21005494) and I have some question about it.
May I get answers here or I should find the right mailing list somewhere else ?
Thanks,
Zoli
Old Dec 11, 2001 | 12:02 PM
3.3.3's Avatar
Default Re: '90 Civic PGM carburetor (pzoltan67)
whats the q?
Old Dec 11, 2001 | 08:12 PM
Gasoline Fumes's Avatar
What's a PGM carburetor?
Old Dec 12, 2001 | 12:33 AM
pzoltan67's Avatar
1, So, I have a book about repairing and maintenancing Civic's, but it not contains
enough informations about the PGM Carburetor.
I would like to know how can I properly set up this type of engine because
I think that mine is not set up properly.
I found some days ago when I started the engine at morning (about -2C°
ambient temperature) that it starts at a high rpm (too high in my opinion) and
after a while the rpm dropped and later the rpm dropped to "normal" (is this
staged rpm drops are normal ?). And a little bit later the rpm slowly lowered
and the engine almost stoped but the rpm increased again.
Anyway I cleaned the windows (ice) while these happend in neutral.
Another thing is that the fuel cosumpion is too high (about 10L/100km), the
acceleration is bad (compared to my previous '86 Civic 1.5 Carb.) and I
sometimes experiencing "dropouts" in acceleration.
(I replaced all oils, valve-gear belt and spark plugs)
So I need informations (step-by-step instructions) about how to find what's
wrong and how to setup this PGM Carburetor engine.
2, Is there any possibility to change cylinder head (and some additional elements)
to convert the engine to dirict injection type ? (what about the cylinder head,
cylinder sizes, crank and crankshaft load ? The hole is the same, as I know,
but what about the stroke ?) Or is it better to change the whole engine ?
Thanks in advance,
Zoltan Perhacs
Old Dec 13, 2001 | 02:32 AM
pzoltan67's Avatar
So, noone can help me ???
Anyway, the PGM carburetor is used from '90 in Civic 1.3 import models.
It is a normal carburetor plus many other elements (including lambda sensor,
air control valve, many "baroswitches" and a computer).
Zoli
[Modified by pzoltan67, 11:39 AM 12/13/2001]
Old Dec 13, 2001 | 11:13 PM
There isn't much you can do with a carb like that. The fast idle spec for my carb is 3000 rpm +/- 500 rpm. So if it's around 3000 rpm when the engine is cold, that's where it should be. Have you replaced or checked the distributer cap and rotor lately?
Old Dec 13, 2001 | 11:24 PM
pzoltan67's Avatar
Default Re: '90 Civic PGM carburetor (Gasoline Fumes)
No, I not checked it yet because it is very cold here now and I don't have
a garage. But I will...
accerat
Nov 16, 2015 04:20 PM
bazzynga
Honda Civic (2006 - 2015)
Sep 6, 2011 08:51 AM
Peewee
May 14, 2003 06:04 PM
joeseph
43
Jan 15, 2003 09:23 AM
pzoltan67
Dec 13, 2001 10:40 PM
