Tranny/clutch Slip Problem
Old Sep 21, 2004 | 07:33 PM
sporty240's Avatar
Default Tranny/clutch Slip Problem
today I took my 90 dx out for a ride after swapping my zc and it feels like my clutch is still slipping. about 5 months ago when I swapped my first zc I got a new exedy clutch on ebay and a different flywheel and a SI tranny, about 2 months later it started to slip.
So I thought i got one of those gay clutches on ebay or my flywheel was bad. I was swapping my zc cause I got a knock from being too lazy to add/change my oil, took it out and the exedy still plenty material left and pplate was barely used, so I was like wtf???
I put in a resurfaced 10lb fly and a slightly used center force dual friction clutch, new throwout and pilot bearings, now its still slipping when I get past like 4k @ full throttle...
is something in my tranny slipping? is my diff going out??
Old Sep 21, 2004 | 07:43 PM
EsCo_EsCo's Avatar
Default Re: Tranny/clutch Slip Problem (sporty240)
these factors may help u out to diagnose the problem:
-adjust freeplay
-no freeplay
-pressure plate springs weak/broken
-overheated disc
there are more that i can list but since u said that u just bought ur clutch i assume that these wouldnt factor in, such as disc badly worn, warped disc or pressure plate.
Old Sep 21, 2004 | 08:06 PM
sporty240's Avatar
Default Re: Tranny/clutch Slip Problem (CReX909)
i think I got it adjusted pretty well, but my clutch does seem to be grab at the end of the pedal release stroke
Old Sep 21, 2004 | 08:10 PM
EsCo_EsCo's Avatar
does the clutch pedal feel soft when it travels to floor?
Old Sep 21, 2004 | 08:17 PM
sporty240's Avatar
yes
Old Sep 21, 2004 | 08:23 PM
EsCo_EsCo's Avatar
how long ago did u put it in? same thing happened with my Sohc zc, the clutch pedal was soft all the way down BUT it didnt slip. does it slip alot?
Old Sep 21, 2004 | 11:07 PM
sporty240's Avatar
at WOT it starts slipping at 4k then catches then slips again...
rpm's also go up and down by about 1000 rpms, but I think it is because of the lightened flywheel
Old Sep 21, 2004 | 11:09 PM
johnzm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 &raquo;</TD></TR><TR><TD CLASS="quote">i think I got it adjusted pretty well, but my clutch does seem to be grab at the end of the pedal release stroke </TD></TR></TABLE>
means it *might* not be disengaging fully. i would get down to the cable adjuste and make sure that the arm down there has at least 1mm of freeplay.
Old Sep 22, 2004 | 11:32 AM
sporty240's Avatar
Default Re: Tranny/clutch Slip Problem (johnzm)
just went out loosened it all the way and readjusted it, its really pouring right now I'll drive it a little later
Old Sep 22, 2004 | 07:10 PM
sporty240's Avatar
still the same under power the clutch/tranny slips..
anybody?
Old Sep 22, 2004 | 07:13 PM
johnzm's Avatar
is oil getting in there from the rear main? thats the only other cause i can think of for a slipping clutch.
Old Sep 22, 2004 | 07:18 PM
sporty240's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">is oil getting in there from the rear main? thats the only other cause i can think of for a slipping clutch.</TD></TR></TABLE>
I doubt its that because this is a diferent engine and flywheel/clutch, and its doing the same thing. Its still the same tranny though, thats why i think its the tranny but not positive...
how do check for that?
Old Sep 22, 2004 | 07:20 PM
sporty240's Avatar
my tranny doesnt grind when shifting but it did make a hissing or shhh sound when it was in gear
Old Sep 23, 2004 | 09:47 AM
sporty240's Avatar
ttt
Old Sep 23, 2004 | 08:44 PM
sporty240's Avatar
any1?
Old Sep 30, 2004 | 07:02 PM
sporty240's Avatar
sometimes when on tha gas, my rpm go up to like 7k and stay there but my speed keeps climing... i know its not the clutch... can anyone help???
stockcrix1616
Mar 14, 2008 01:46 AM
B18cHatch4u
Sep 16, 2005 03:16 PM
91_civic_si_guy
May 2, 2005 06:05 PM
camboMONK
Apr 1, 2003 07:15 PM
crxdohczc
Mar 3, 2003 07:40 PM
